Knowledge Base Article
Why does the DisplayPort Intel® FPGA Receiver IP Core with "Enable GPU Control" option unchecked fail to acknowledge I2C-over-AUX requests coming from Host DisplayPort Transmitter ?
Description
Due to a problem in the DisplayPort Intel® FPGA Receiver IP core prior to Intel® Quartus® Prime Pro Edition version 18.1 software and prior to Intel® Quartus® Prime Standard Edition version 19.1 software, the DisplayPort Intel® FPGA Receiver IP core may not acknowledge I2C-over-AUX requests coming from Host DisplayPort Transmitter which can cause system black screen scenario.
This problem doesn't affect the DisplayPort Intel® FPGA Receiver IP core with "Enable GPU Control" option checked.
Resolution
To work around this problem, turn on the "Enable GPU Control" option in the DisplayPort Intel® FPGA Receiver IP Core and use DisplayPort Intel® FPGA Nios II API to manage the AUX channel handshaking.
This problem is fixed beginning with Intel® Quartus® Prime Standard Edition version 19.1 software and Intel® Quartus® Prime Pro Edition version 18.1 software.
Updated 3 months ago
Version 2.0
