Knowledge Base Article
Why does niosv-download return “Invalid reset option” when executing reset from debug module?
Description
Due to a problem in the Ashling RiscFree IDE for Altera® software, the niosv-download returns “Invalid reset option” when executing reset from debug module for designs targeting Nios® V processor.
The affected versions are:
  • Software version 25.2.1 (version dated 9th May 2025, paired with Quartus® Prime Pro software version 25.1.1 and Quartus® Prime Standard software version 25.1)
  • Software version 25.3.1 (version dated 1st Aug 2025, paired with Quartus® Prime Pro software version 25.3.1)
  • Software version 25.4.1 (version dated 31st Oct 2025, paired with Quartus® Prime Pro software version 26.1)
The problem is caused by Ashling GDBServer failing to execute software reset (swreset), and niosv-download is using Ashling GDBServer to communicate with the processor.
Thus, this failure prompts the “Invalid reset option” message when executing “niosv-download –r".
Resolution
To work around this problem, use the argument “-o” to change from Ashling GDBserver to OpenOCD.
$ niosv-download –r -o
 This problem is fixed beginning with the Ashling RiscFree IDE for Altera® Quartus® software version 26.1.1-C, which is paired with Quartus® Prime Pro software version 26.1.1.
Related Articles
NIOS V/m dbg_reset_out signal (Q25.1 Std, MAX10) | Altera Community - 352387
Updated 6 months ago
Version 4.0
