Knowledge Base Article
Why does niosv-download fail with a non-pipelined Nios® V/m processor at JTAG frequency 24MHz or 16Mhz?
Description
This issue may be seen in Quartus® Prime Pro Edition Software version 23.3 and later when downloading Nios® V processor software into a non-pipelined Nios® V/m processor.
This is due to processor limitation, affecting the non-pipelined Nios® V/m processor only.
Other processors below are not affected by this limitation:
  • Pipelined Nios® V/m processor
  • Nios® V/g processor
Resolution
To work around the problem, follow the steps below:
1. Use the command to set the JTAG clock frequency to 6Mhz:
    jtagconfig --setparam 1 JtagClock 6M
2. Re-download the Nios® V processor .elf file.
Updated 1 year ago
Version 2.0
