Knowledge Base Article
Why does my design containing the Mailbox Client IP not compile after upgrading to Quartus® Prime Pro Edition software version 25.1?
Description
Due to a problem with the Quartus® Prime Pro Edition software version 25.1, designs containing the Mailbox Client IP might fail during compilation after upgrading the IP. This problem affects designs targeting any Stratix® 10 FPGA or Agilex® FPGA device and containing both the Mailbox Client IP and the Advanced SEU Detection IP. If the Mailbox Client IP is upgraded but the Advanced SEU Detection IP has not been upgraded, you might see error messages during Analysis & Synthesis, such as:
Error(13452): Verilog HDL Module Instantiation error at <filename>: module "altera_config_stream_endpoint_wrapper" has no parameter named "TYPE_NAME" -
Error(13452): Verilog HDL Module Instantiation error at <filename>: module "altera_config_stream_endpoint_wrapper" has no parameter named "INSTANCE_NAME"
Resolution
To avoid this problem, upgrade the Mailbox Client IP and the Advanced SEU Detection IP, even if the upgrade status is Recommended, not Required.
A patch is available to fix this problem for the Quartus® Prime Pro Edition software version 25.1. Download and install patch 0.01 from the following links:
- Quartus® Prime Pro Edition Design Software v25.1 Patch 0.01 for Windows (.exe)
- Quartus® Prime Pro Edition Design Software v25.1 Patch 0.01 for Linux (.run)
- Readme for Quartus® Prime Pro Edition Design Software v25.1 Patch 0.01 (.txt)
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.1.1.
