Knowledge Base Article
Why does GD55LB02GE QSPI flash fail in Linux* in FPGA SoC device?
Description
If you use Linux* version between socfpga-6.0 and socfpga-6.12.43-lts with GD55LB02GE QSPI flash, you may fail to mount the file system in Linux if it’s stored in GD55LB02GE. This is caused by the gigadevice.c in these versions.
Resolution
This issue is fixed in socfpga-6.12.43-lts and afterwards. You can upgrade Linux source code to this version, or comment out the GD55LB02GE entry in gigadevice.c in old versions.
Updated 3 months ago
Version 4.0
