Knowledge Base Article
Why does Ashling* RiscFree* IDE for Altera® FPGAs detect Core 0 only in a Nios® V processor multicore system?
Description
Due to a problem in the Ashling* RiscFree* IDE for Altera software version 25.2.1 (version dated 9th May 2025), the Ashling* RiscFree* IDE might fail to detect other Nios® V processor cores (except Core 0) for Nios® V processor multicore designs.
This is because there is a bug in the Ashling* GDBServer software.
Error message:
[GDB server output] Error: The device configuration selected has only 1 core (Core 0). Core 1 is not available.
Resolution
To workaround this issue, please switch from Ashling* GDBServer to Open On-Chip Debugger (OpenOCD) when debugging a Nios® V multicore processor system.
  • Add the “–o" argument when running niosv-download.
niosv-download app.elf -o <options>
This problem is scheduled to be fixed, beginning with the Ashling* RiscFree* IDE for Altera software version 25.3.1 (version dated 1st August 2025).
Published 1 month ago
Version 1.0
