Knowledge Base Article
Why do the parsing results of a SOF file for Configuration via Protocol (CvP) created for Stratix® 10 FPGA or any of the Agilex® FPGA families indicate that the file is CvP disabled?
Description
Due to a problem in Quartus® Prime Pro Edition Software version 24.3 and earlier, parsing SOF programming files using the method refered to in AN 955: Programmer's Configuration Debugger Tool will output a result which indicates that the SOF file generated from a project using Configuration via Protocol (CvP) is not enabled for CvP.
This problem affects SOF files created for CvP targeting any Stratix® 10 FPGA or Agilex® FPGA family device.
Resolution
This issue does not affect functionality, and you can ignore this discrepancy.
When you convert the SOF file to any other file programming format you plan to use CvP with, the parsing of the generated file will indicate that the file is enabled for CvP.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.1.1.
