Knowledge Base Article
Why do I see hold time violations in the Low Latency 40G Ethernet Intel® FPGA IP core when KR4 is enabled?
Description
Due to a problem with the Low Latency 40G Ethernet Intel® FPGA IP core on Intel® Stratix® 10 FPGA, you might see minor hold time violations when the KR4 feature is enabled.
Resolution
A possible temporary work around for this timing problem is to run seed sweeps so that better timing results are found.
This problem is scheduled to be fixed in a future release of the Intel® Quartus® Prime Software.
Updated 1 year ago
Version 2.0
