Knowledge Base Article
Why am I seeing Deterministic Latency Accuracy problems when using Inter-protocol Designs in the GTS Dynamic Reconfiguration Controller IP?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.3 and earlier, you may inter-protocol GTS Ethernet Hard IP with PTP and GTS CPRI IP in GTS Dynamic Reconfiguration Controller IP designs.
Resolution
Currently, there is no workaround for this problem.
This problem is scheduled to be fixed in the future release of the Quartus® Prime Pro Edition software. 
Related IP Core
  • GTS Dynamic Reconfiguration Controller IP
  • GTS Ethernet Hard IP with PTP
  • GTS CPRI IP
Published 10 months ago
Version 1.0
