Knowledge Base Article
What is the latest device firmware for the Quartus® Prime Pro Edition Software version 24.3.1?
Description
The latest device firmware for the Quartus® Prime Pro Edition Software version 24.3.1 can be downloaded from the following links.
Fixes for the following problems are included in the latest release (The newest release contains all prior fixes and supersedes earlier device firmware releases).
Change Log
Firmware version 1.01fw:
This patch fixes an issue on Agilex® 7 FPGA devices where the HPS may become stuck at the First Stage Bootloader (FSBL).
Firmware version 1.06fw:
This patch includes EMIF and HBM2e firmware updates for Agilex® 7 M-Series ES and production devices.
Firmware version 1.15fw:
This patch fixes an issue where SDM hangs when reconfiguring back-to-back.
Please also see the following links:
- Updating the SDM Firmware in the Agilex® 7 FPGA Configuration User Guide
- Updating the SDM Firmware in the Stratix® 10 FPGA Configuration User Guide
Resolution
Download the latest device firmware below.
Note:
- Patches must be applied to the Quartus® Prime Pro Edition Software and the Quartus® Prime Pro Edition Software Programmer and Tools.
- Recompilation is not required.
- All programming files should be recreated.
- Re-run the programming file generation or conversion using the Quartus® Prime Software programming file generator.
