Knowledge Base Article
What is the latest device firmware for the Quartus® Prime Pro Edition Software version 24.3?
Description
The latest device firmware for the Quartus® Prime Pro Edition Software version 24.3 can be downloaded from the following links.
Fixes for the following problems are included in the latest release (The newest release contains all prior fixes and supersedes earlier device firmware releases).
Change Log
Firmware version 0.12fw:
This patch fixes potential HBM2E calibration issues for Agilex™ 7 M-Series devices.
Firmware version 0.22fw:
This patch fixes a rare scenario issue where the device hangs when reconfiguring back-to-back. The fix includes an update to the polling scheme in firmware to address the issue.
Firmware version 0.25fw:
This patch fixes an issue on Agilex™ 7 devices where the HPS may become stuck at the First Stage Bootloader (FSBL).
Please also see the following links:
- Updating the SDM Firmware in the Agilex™ FPGA Configuration User Guide
- Updating the SDM Firmware in the Stratix® 10 FPGA Configuration User Guide
Resolution
Download the latest device firmware below.
Note:
- Patches must be applied to the Quartus® Prime Pro Edition Software and the Quartus® Prime Pro Edition Software Programmer and Tools.
- Recompilation is not required.
- All programming files should be recreated.
- Re-run the programming file generation or conversion using the Quartus® Prime Software programming file generator.
