Knowledge Base Article
SEVERE: An error occurred while running script "::emif_cal_dbg::odt_cal::run_odt_cal_callback
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 20.2, you may see a similar error to the one shown below when a calibration failure occurs in the Intel Stratix® 10 EMIF Unified Calibration Debug Toolkit or the Intel Agilex® 3 FPGA EMIF Debug Toolkit.
SEVERE: An error occurred while running script"::emif_cal_dbg::odt_cal::run_odt_cal_callback
": ed_synth_inst: key "65542" not known in dictionary
while executing
"dict get $dictionary $key"
(procedure "::emif_cal_dbg::util::family_expert::get_dict_elem" line 3)
invoked from within
"::emif_cal_dbg::util::family_expert::get_dict_elem cal_stage [expr $val]"
Resolution
This example error message displays an error code “65542” when a calibration failure occurs and is not reported by the EMIF Toolkit.
For the Intel® Stratix® 10 EMIF Unified Calibration Debug Toolkit, below is a list of the calibration stages and associated error codes that are not reported.
Calibration Stage                                             Error Code
WRITE_LEVEL_EDGE                                           65541
WRITE_LEVEL_CLOCK                                         131077
WRITE_DESKEW_DM_CENTER                          65542
MARGINING_DQ                                                   65547
MARGINING_DM                                                   131083
For the Intel Agilex® 3 FPGA EMIF Debug Toolkit, below is a list of the calibration stages and associated error codes that are not reported.
WRITE_LEVEL_EDGE:                                          65541
WRITE_LEVEL_CLOCK:                                        131077
WRITE_DESKEW_DM_CENTER:                          65542
READ_DESKEW_DBI_CENTER:                           65540
Updated 11 months ago
Version 2.0
