Knowledge Base Article
Internal Error: Sub-system: CPLL, File: /quartus/periph/cpll/cpll_gen8.cpp
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.1 and earlier, you might see this internal error during the Place Stage when compiling the IOPLL FPGA IP. This internal error occurs when enabling the option "Refclk source is global clock" of the IOPLL FPGA IP.
Resolution
To work around the problem, modify the Verilog code in the submodule file <*>_altera_iopll_2000_<*>.v of the IOPLL FPGA IP as the followings:
From
.clkin_0_src("coreclkin"),
to
.clkin_0_src("ioclkin_0"),
This problem has been fixed starting with Quartus® Prime Pro Edition software version 25.3.1.
Updated 4 months ago
Version 5.0
