Knowledge Base Article
add_instance: Component intel_niosv_m_unit version <x.y> is not installed - loaded latest installed version <x.y> instead. Please check for parameter mismatches.
Description
Platform Designer may show an “add_instance” warning message from the Nios® V Processor Intel® FPGA IP  in the Intel® Quartus® Prime Pro Edition Software v21.4 when,
  • Instantiating the Nios® V Processor Intel® FPGA IP.
  • Performing an IP Upgrade on the same IP from software version 21.3 to 21.4.
This is due to a mismatch with the IP version number in the Intel Quartus Prime Software.
The full warning message reads as:
add_instance: Component intel_niosv_m_unit version 21.1.0 is not installed - loaded latest installed version 21.1.1 instead. Please check for parameter mismatches.
Resolution
To work around this problem, download and install the patch for the Intel® Quartus® Prime Pro Edition Software v21.4.
Download and install Patch for version 21.4 from the following links:
Updated 8 months ago
Version 3.0
