16 years agoSimple Socket Server on DE2 w/Davicom DM9000A
updated.
Altera's Simple Socket Server demo running on a DE2 board with the Davicom DM9000a driver. here it is....zipped downloaded project source for sss on the de2 board. download link currently unavailable. Includes: - Hardware design (TLD in schematic block diagram format) - Programmable .SOF (time-limited, as developed in Quartus Web Edition v9.2) - SOPC builder system file - DM9000A driver for Nichestack TCP/IP stack / Altera HAL environment (courtesy of Columbia Uni) - Simple socket server software Simply... - (1) Download the .SOF in Quartus Programmer - (2) Open the software workspace in the "/software" directory in Nios II Build Tools (Eclipse IDE) - (3) Open Run >> Run Configurations. Delete the current configuration. Create a new launch configuration selecting the project name under the Project Tab. Ensure your DE2 board is plugged into USB. Check the target connection tab and make sure it is present. - (4) Plug into your local network (DHCP is enabled, or app will default to static IP) - (5) View the Nios II console for debugging information (via JTAG UART) - (6) Telnet into the board from a pc: telnet <ip address> 30. Enjoy the simple socket server demo from Altera! Questions/comments? Fire away below!98 Replies
--- Quote Start --- Ok When i open IDE Eclipse, i select a workspace ( i created a new workspace) when the platform opens i choose File -> new -> Nios II Aplication and BSP from Template. Then i select the sopcinfo file , which was in the zip-order and choose an Projectname (ethernetconnection) and choose simple socket server and 'finish'. then run -> run configurations-> NIOS II HARDware-> new configuration and selcet the Projectname( ethernetconnection). but under Elf File name there is no object which you can select, there is only an empty field. so i cant run the project. have i forgotten something? or how can i solve this problem? --- Quote End --- Make sure you have successfully built the project first! Sounds like the ELF is missing as the project hasn't been built. Normally if you just hit Run, the project is built prior to deploying to your Nios processor. - Altera_Forum
ok i can choose the ELF, but when i click run i get the masseage ' download elf process failed' and on the console :Verify failed between address 0x800000 and 0x80FFFF
--- Quote Start --- ok i can choose the ELF, but when i click run i get the masseage ' download elf process failed' and on the console :Verify failed between address 0x800000 and 0x80FFFF --- Quote End --- Are you able to post a screenshot of the console/showing the error? - Altera_Forum
hey,tnndesign
i use DM9000+LWIP+UCOS,but U know the NIOS II IDE'LWIP just support the lan91c111 ,how can i use the DM9000 with LWIP,AND the your NICHESTACK must the same with me, but how you solve it? thanks - Altera_Forum
--- Quote Start --- hey,tnndesign i use DM9000+LWIP+UCOS,but U know the NIOS II IDE'LWIP just support the lan91c111 ,how can i use the DM9000 with LWIP,AND the your NICHESTACK must the same with me, but how you solve it? thanks --- Quote End --- Dison. I'm using the DM9000a controller with the latest Nichestack TCP/IP library provided by Altera. I believe LWIP was supported in a prev version of the Nios Tools Suite, however Altera have since moved to the Micrium uCOS/OS-II + Nichestack platform combination for TCP/IP. If you are running a previous version of the Nios Design Tool and/or you would like to use LWIP, check out the DE2_WEB example from Terrasic. They include a custom-written driver for the DM9000a for use with LWIP. The solution I have posted is for use with the latest Altera ref design for a simple socket server. It provides DM9000a driver support for use w/Nichestack. - Altera_Forum
--- Quote Start --- ok i get this message every time i try to run the programm --- Quote End --- Certainly unusual. If I didn't know better, would say this is a timing issue, but as long as you are using the SOF file in the Quartus directory you shouldn't be having any trouble. Program memory is set to the SDRAM chip which requires a PLL to compensate for clock skew (approx -3ns shift). This is already included in the H/W design files. When you program the "time-limited" SOF in Quartus Programmer, are you able to successfully program the configuration into the FPGA over JTAG? Does the Opencore IP Evaluation popup open and say "Time Remaining: Unlimited"? - Altera_Forum
Sorry i didn´t answer i was on holiday. There is an error when i use the time-limited-sof:
"Error: Can't communicate with device. Device will stop functioning when it reaches its non-tethered mode timeout limit." But i don´t know how to handle it, the device has power and the usb-blaster cable works, too. But when i use the other NiosIIfDesign-Sof (not time limtied) there is no error in Quartus but the error in Nios by downloading the elf-process is still there. - Altera_Forum
That's your problem right there - due to the time-limited features used in the SOPC design, the Opencore IP popup must stay open otherwise you'll encounter errors downloading the ELF file.
Make sure you are running Quartus 9.1SP2 (Web Edition) and NIOS II EDS 9.1. Try rebuilding the Quartus Project to regenerate the SOF. Everything builds and downloads successfully in 9.1SP2 which I am using - so there shouldn't be any problem there. - Altera_Forum
Oh i have the smsc lan91c111 on my board so i can´t take the dm9000a which you have used, right?
