16 years agoSimple Socket Server on DE2 w/Davicom DM9000A
updated. Altera's Simple Socket Server demo running on a DE2 board with the Davicom DM9000a driver. here it is....zipped downloaded project source for sss on the de2 board. download link c...
16 years ago --- Quote Start --- Ok When i open IDE Eclipse, i select a workspace ( i created a new workspace) when the platform opens i choose File -> new -> Nios II Aplication and BSP from Template. Then i select the sopcinfo file , which was in the zip-order and choose an Projectname (ethernetconnection) and choose simple socket server and 'finish'. then run -> run configurations-> NIOS II HARDware-> new configuration and selcet the Projectname( ethernetconnection). but under Elf File name there is no object which you can select, there is only an empty field. so i cant run the project. have i forgotten something? or how can i solve this problem? --- Quote End --- Make sure you have successfully built the project first! Sounds like the ELF is missing as the project hasn't been built. Normally if you just hit Run, the project is built prior to deploying to your Nios processor.
