16 years agoSimple Socket Server on DE2 w/Davicom DM9000A
updated. Altera's Simple Socket Server demo running on a DE2 board with the Davicom DM9000a driver. here it is....zipped downloaded project source for sss on the de2 board. download link c...
16 years agoThat's your problem right there - due to the time-limited features used in the SOPC design, the Opencore IP popup must stay open otherwise you'll encounter errors downloading the ELF file.
Make sure you are running Quartus 9.1SP2 (Web Edition) and NIOS II EDS 9.1. Try rebuilding the Quartus Project to regenerate the SOF. Everything builds and downloads successfully in 9.1SP2 which I am using - so there shouldn't be any problem there.
