PROBLEM LOADING with MONITOR PROGRAM 18.1 TO DE2-115
I am following the tutorial that presents an introduction to PLATFORM DESIGNER tool (link bellow)
Everything is OK till the last step (in step 9 page 31), when selecting "Actions > Compile & Load" , an error message appears says:
"could not query jtag instance ids, please ensure the fpga has been configured using the correct .sof file."
I am using:
*Quartus prime Lite edition 18.1.
* Intel FPGA Monitor Program 18.1.
*DE2-115 board.
on Win 10.
Please any one have fixed this problem.
Regards...
- ShengN_altera
Check this link https://habr.com/ru/post/464795/
Tried to open the NIOS II console:
There I went to the directory where the sof file is located and entered the command line:
system-console --script=jtag_instance_check.tcl USB-0 <file_name>.sof
For the command line above, you have to copy the ..\University_Program\Monitor_Program\bin\jtag_instance_check.tcl to the same place where sof is, so as not to suffer with the path. As a result, I got a pretty decent response.
Sheng
- ShengN_altera
Hi @kopdcom ,
Any further concern or update?
Does the problem being resolved?
Sheng
- kopdcom
Dear Sheng,
Thank you a lot for taking my request into consideration.
Sorry for being late to response, but actually, I have to wait till sunday to access to our Lab and try the solution.
Thank you again, and a feedback will be sent in sunday.
with best regards...
- kopdcom
Dear Sheng,
I have followed step by step as you mentionned ( https://habr.com/ru/post/464795/ ). a same message appears in the nios II console when following the steps of the solution and typing the instruction:
The message looks like:
TYPE_NAME * FULL_HPATH nios_systeme:Nios|nios_system_jtag_quart_0....................(INSTANCE_ID:0)
TYPE_NAME * FULL_HPATH nios_systeme:Nios|nios_system_nios2_qsys_0...................(INSTANCE_ID:0)
Unfortunatly, the error message still occur:
But, it should to mentionned that before doing this solution, I could not selecting COMPILE or LOAD separatly in the monitor program (in ACTIONS tab) juste I could select COMPLE & LOAD, but now, I can chose COMPILE, and it's OK, but when choosing LOAD after COMPILE, the previous error return.
I hope that I have well clarified.
Regards...
- ShengN_altera
Hi @kopdcom ,
Are you using USB-1 for Host connection image below?
May be have to use this system-console --script=jtag_instance_check.tcl USB-1 <file_name>.sof
Sheng
- kopdcom
Dear Sheng,
I have confirmed, It's USB-0.
I will try the next solution...
- ShengN_altera
Hi @kopdcom ,
Or try to replace the code section below in tcl script jtag_instance_check.tcl:
# PRINT OUT INSTANCE ID INFO FOR EVERYTHING:
set i 0
foreach path [lsort -command compare_node_number [get_service_paths bytestream]] {
# If this path corresponds to a JTAG UART, incr i
if {[string match *$cable_name* $path ] && [string match *jtag_uart* [marker_get_type $path] ]} {
puts "[marker_get_info $path] (INSTANCE_ID:$i)"
incr i
set i 0
foreach path [lsort -command compare_node_number [get_service_paths processor]] {
# If this path corresponds to a NiosII, incr i
if {[string match *$cable_name* $path ] && [string match *nios2* [marker_get_type $path] ]} {
incr i
With the code section below:
set i 0
set info [marker_get_info $path]
if {[string first "|" $info] == -1} {
set info [string map {"FULL_HPATH " "FULL_HPATH a:b|"} $info]
puts "$info (INSTANCE_ID:$i)"
incr i
set i 0
incr i
Sheng
- kopdcom
Dear Sheng,
I have replaced the code section mentionned in jtag_instance_check.tcl, unfortunatly, still the same error message. I have made screen-prints of all steps:
** Nios II Console:
** Downloading the system associated with the project:
-----------------------------------------------------Info& Erros:-----------------------------------------------------
C:/intelFPGA_lite/18.1/quartus/bin64/quartus_pgm -c "USB-Blaster [USB-0]" --auto
1) USB-Blaster [USB-0]
020F70DD 10CL120(Y|Z)/EP3C120/..
Info: *******************************************************************
Info: Running Quartus Prime Programmer
Info: Version 18.1.0 Build 625 09/12/2018 SJ Lite Edition
Info: Copyright (C) 2018 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details.
Info: Processing started: Mon Oct 31 13:49:56 2022
Info: Command: quartus_pgm -c "USB-Blaster [USB-0]" -m jtag -o P;C:/intelFPGA_lite/18.1/lights.sof@1
Info (213045): Using programming cable "USB-Blaster [USB-0]"
Info (213011): Using programming file C:/intelFPGA_lite/18.1/lights.sof with checksum 0x00687B2D for device EP4CE115F29@1
Info (209060): Started Programmer operation at Mon Oct 31 13:49:57 2022
Info (209016): Configuring device index 1
Info (209017): Device 1 contains JTAG ID code 0x020F70DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Mon Oct 31 13:50:04 2022
Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 312 megabytes
Info: Processing ended: Mon Oct 31 13:50:04 2022
Info: Elapsed time: 00:00:08
Info: Total CPU time (on all processors): 00:00:10------------------------------------------------------------------------------------------------------------------------
** After choosing COMPILE (in ACTIONS tab):
** After choosing LOAD (in ACTIONS tab):
Regards...
- ShengN_altera
Hi @kopdcom ,
Sorry for misdirection. For Monitor Program, supposedly have to follow this document link below (located in ..\University_Program\Monitor_Program\tutorial\Intel_FPGA_Monitor_Program_NiosII.pdf
and have to use DE1-SoC device.
Steps summary:
- Creating a Project
- Specify a system: DE1-SoC Computer. It is represented by .sopcinfo and .sof files which are automatically included when this computer is selected. The DE1-SoC preloader is also automatically selected.
- Specify a program type: Assembly Program. Click on the selection Include a sample program with the project. Select the program named Simple Program.
- Specify program details: the source code file(s) associated with this program is listed in the Source files box.
- Specify system parameters: DE-SoC [USB-1]
- Specify program memory settings
Sheng
- kopdcom
Dear Sheng,
It is written in the first page of this tutorials:
"In this tutorial it is assumed that the reader has access to the Intel DE1-SoC Development and Education board, connected to a computer that has Quartus Prime and Nios II Embedded Design Suite (EDS) software
installed".But in our Lab, we have just the DE2-115 board. So I want to know if this tutorial is just for the DE1-SoC Board or I can try it on DE2-115.
Regards...
- ShengN_altera
Yes. The configuration in that particular tutorial is just mainly for DE1-SoC Board. There are also other systems available for Monitor Program which are DE0-CV, DE0-Nano, DE0-Nano-SoC, DE10-Lite and DE10-Nano.
Sheng
