ShengN_altera
3 years agoHi @kopdcom ,
Any further concern or update?
Does the problem being resolved?
Sheng
kopdcom
3 years agoDear Sheng,
I have followed step by step as you mentionned ( https://habr.com/ru/post/464795/ ). a same message appears in the nios II console when following the steps of the solution and typing the instruction:
system-console --script=jtag_instance_check.tcl USB-0 <file_name>.sof
The message looks like:
TYPE_NAME * FULL_HPATH nios_systeme:Nios|nios_system_jtag_quart_0....................(INSTANCE_ID:0)
TYPE_NAME * FULL_HPATH nios_systeme:Nios|nios_system_nios2_qsys_0...................(INSTANCE_ID:0)
Unfortunatly, the error message still occur:
"could not query jtag instance ids, please ensure the fpga has been configured using the correct .sof file."
But, it should to mentionned that before doing this solution, I could not selecting COMPILE or LOAD separatly in the monitor program (in ACTIONS tab) juste I could select COMPLE & LOAD, but now, I can chose COMPILE, and it's OK, but when choosing LOAD after COMPILE, the previous error return.
I hope that I have well clarified.
Regards...
Regards...
