ktabacchi
9 months agoWhy do I intermittently see reboot failure in the u-boot stage when running the Arria 10?
Hello, We are seeing intermittent failures in u-boot on warm reboot. U-Boot version: 2023.01Device: Arria10 To reproduce: Power on the system and let it boot. In the shell type the `reboot` c...
ktabacchi
9 months agoAlso, a quick scan of the Quartus version 25.3 release notes doesn't list this as a fix. Would you mind pointing to the bug/issue number for this fix?
Thanks!
tehjingy_Altera
8 months agoDear Customer,
Since a solution is provided and no further clarification is needed on this thread, it will be transitioned to community support for further help on doubts in this thread.
Please login to the Altera Community Forum and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you for the questions and as always pleasure having you here.
Best Wishes
Altera Tech Support
