Unable to run make file on ALtera SOC EDS
Im not able to complite the makefile and main.c file to make a executable file, I'm trying to execute the project on DE1soc hps linux, Im trying compile my_first_hps project.
$ ls
main.c Makefile
girid@LAPTOP-T0N0O46H ~/OneDrive/Documents/3875/my_first_hps
$ make
arm-linux-gnueabihf-gcc -g -Wall -Dsoc_cv_av -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include/soc_cv_av -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include/ -c main.c -o main.o
process_begin: CreateProcess(NULL, arm-linux-gnueabihf-gcc -g -Wall -Dsoc_cv_av -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include/soc_cv_av -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include/ -c main.c -o main.o, ...) failed.
make (e=2): The system cannot find the file specified.
make: *** [main.o] Error 2
$ echo $SOCEDS_DEST_ROOT
$ make
Make file:
- GirideshSekar
Hello, this is a bit urgent, can someone help me with this, this might be crucial going forward into the project I'm currently working on. Thanks and I appreciate any help provided.
- BXia
Based on my experience, you'd better to reinstall the soc eds software, you need to install the ds-5 software together after installing the soc eds. And the version of soc eds should be same to Quartus.
- Jeet14
Please follow the steps given for SoCEDS and ARM DS installation.
https://www.rocketboards.org/foswiki/Documentation/SoCEDS
Once installation is done then you can start an Embedded Command Shell by going to
For 20.1 Pro: Start menu > Intel FPGA 20.1 Pro Edition > SoC EDS Command Shell.
For 20.1 Std: Start menu > Intel FPGA 20.1 > SoC EDS Command Shell.
Create the helloworld example from the given example templates. This will compile and generate the .axf or .elf file of helloworld application.
Tiwari
- Jeet14
Let me know if you have any further question on this.
Tiwari
- Jeet14
- GirideshSekar
Greeting, thankyou for your reply. i installed the arm -gnueabihf from the internet to make it work. This folder was not part of installation and linux based executions required this . thanks
