Jpasquiet
2 years agoUnable to run Generic Serial Flash Interface IP at 100 MHz
Hi, I am working on a Cyclone V, writing an epcq128A using Generic Serial Flash Interface Intel IP. After integrating the IP and connected it to the HPS in the platform designer, I am now able to...
FakhrulA_altera
2 years agoHi Jpasquiet,
I wish to follow up with you on this case. Do you still have further inquiries on this issue? Please feel free to let me know if there is any concern so that we could further assist you.
Otherwise, this thread will be idling and marked as inactive, thus it will be transitioned to community support because there is no update received from you in a while.
Fakhrul
- Jpasquiet2 years ago
Hi @Fakhrul ,
Thank you for your time and your answer.
I've switched to another task for the moment, thus I havn't been able to try adding more of interval cycles between instructions from CSR port as mentionned on the post, however I am keeping this information in mind and I'll not miss to mark this topic as solved if it works.
Jpasquiet
