ohfpga1
7 months agoTimings eMMC
Hi, latest datasheet of SoC « 813918/2026.01.05 » lists in paragraph « HPS SD/eMMC Timing Characteristics » the constraints of eMMC, applicable to memory component but does not define any timing dat...
KianHinT_altera
7 months agoHi ohfpga1
Could you refer to the Agilex 5 datasheet under SD/EMMC timing characteristics (https://docs.altera.com/r/docs/813918/current/agilextm-5-fpgas-and-socs-device-data-sheet/agilextm-5-fpgas-and-socs-device-data-sheet)
Example for legacy, HS_SDR
There is also timing tables for the rest of the modes eg (HS,HS200, HS400). Could you refer to the document and see whether it addresses your timing question?
Kian
