Reg Agilex5 A5ED028BM16AE5S SoC - USB3.0
- 1 month ago
Hi Amol
As there are no further inquiries during this period and the answer already been provided, I will step back and allow the community to assist with any future follow-up questions.
Altera Technical Support
Hi Amol,
Is there any further question related to this case, otherwise I would like to revert this thread to community support for future discussion.
Kian
Hi Kian,
Customer want to use HPS for USB3.0 implementation
so want to know if can transmit 5Gbps or less speed.
amol
- KianHinT_altera1 month ago
Hi Amol
Altera Technical Support - KianHinT_altera1 month ago
Just to recap:
The Agilex 5 HPS fully supports USB 3.0/3.1 Gen 1 at 5 Gbps and all lower speeds. Here's the full picture:
USB Controller Overview
The Agilex 5 HPS includes one USB 3.1 Gen 1 controller in addition to a separate USB 2.0 OTG controller. Agilex™ 5 FPGAs and SoCs Device OverviewThe USB 3.1 Gen 1 controller is a Synopsys IP, version 1.90a. Hard Processor System Technical Reference Manual
Supported Speeds
The USB 3.1 controller supports the following speeds:
- SuperSpeed (SS) — 5 Gbps
- High Speed (HS) — 480 Mbps
- Full Speed (FS) — 12 Mbps
- Low Speed (LS) — 1.5 Mbps
In host mode, all speeds are supported. However, in device mode, low speed is not supported. Hard Processor System Technical Reference Manual
PHY Interface for SuperSpeed
The USB 3.1 Gen 1 controller supports up to 5 Gbps when configured for USB 3.1 Gen 1 and interfaced with the transceiver, and up to 480 Mbps when configured for USB 2.0 and interfaced with HPS I/O. Agilex™ 5 FPGAs and SoCs Device OverviewThe USB 3.1 controller uses a ULPI interface to the PHY for USB 2.0 operations and a PIPE3 interface to the GTS transceiver for SuperSpeed mode. Hard Processor System Technical Reference ManualThe GTS transceiver situated closest to the HPS is specifically reserved for the USB 3.1 protocol. The USB 3.1 controller is implemented within the HPS subsystem while the PCS and PHY portions are implemented within the GTS transceiver. Hard Processor System Technical Reference Manual
Host vs. Device Mode Concurrency
In host mode, both USB 2.0 and USB 3.1 operations can be simultaneously active to concurrently support USB 2.0 and USB 3.1 devices. However, in device mode, because the controller connects as either a USB 2.0 device or a USB 3.1 device, only one of these operations is active at a given time. Hard Processor System Technical Reference Manual
Real-World Throughput (Agilex 5 Premium Development Kit)
The attached performance data measured on the Agilex 5 Premium Development Kit with a USB thumb drive shows real-world throughput well within the 5 Gbps envelope:
- Host mode average: ~314.7 MB/s write, ~366.2 MB/s read
- Device mode average: ~327.0 MB/s write, ~394.0 MB/s read
The note on that data states the maximum theoretical speed is 625 MB/s and real-world speeds are typically in the 300–450 MB/s range — consistent with SuperSpeed USB overhead.
System Bus Bandwidth
The USB 3.1 controller's system bus bandwidth is (2.43 × 1 + 0.5 × 1) Gbps = 2.93 Gbps total (combining the SuperSpeed and High-Speed bus instances). Hard Processor System Technical Reference Manual
Boot Note
In HPS Boot First mode, the USB 3.1 controller can only be used after "Phase 2 configuration." Hard Processor System Technical Reference Manual Make sure the customer's boot flow accounts for this if they are using HPS Boot First mode.
Bottom line: the Agilex 5 HPS USB 3.1 Gen 1 controller fully supports 5 Gbps SuperSpeed operation, as well as all lower USB speeds, in both host and device modes.
