Repeated EDAC SEU UE Errors on Agilex 7 AGI027FB
Hi Rajas,
Sorry for the delay in getting back, didnt notice Lok actually replied earlier, was waiting for the KDB to be release but unfortunately, it was delayed and needs to be reviewed again due to issues in the KDB document. I'm not able to share any unpublished documents in public. Meanwhile, I'm checking with the author of the KDB mentioned previously on for the settings recommendation for Agilex 7 I-series and maybe direct message you directly.
Kian
Hi Rajas,
Just to recap from direct message in case anyone encounter similar behavior,
For the Agilex 7 I-series, it is the same or the issue with the same root cause as the F-series.
The recommended voltage limits values you must set are universal for all Voltage Regulators (VR) when use as the SmartVID voltage regulators
Specifically for Agilex 7 we recommed the following values
VOUT_OV_WARN_LIMIT to VID_MAX 927mV
VOUT_OV_FAULT_LIMIT to VID_MAX 930mV
VOUT_MAX to VID_MAX 950mV
VOUT_UV_WARN_LIMIT to VID_MIN 690mV
VOUT_UV_FAULT_LIMIT to VID_MIN 680mV
This is to cover all the range of values the SmartVID voltage can take ,so you see is the same values on the KDB with exception for the VOUT_MAX which is larger
The recommendation is also in the guide 5.1.2.4. Fault Management and Error Reporting • Agilex® 7 Power Management User Guide • Altera Documentation and Resources Center
Do you have any further questions on this case?
Kian
