Repeated EDAC SEU UE Errors on Agilex 7 AGI027FB
Hi Rajas Patil
Thanks for using our Altera forum. I did a quick check on your error code and seems this issue been reported on Agilex 7 F-series and there is a KDB on it. However as the KDB configuration is targetted on F-series, I will need to confirm with our engineering team for I series.
https://community.altera.com/kb/knowledge-base/why-do-i-see-seu-errors-being-detected-consistently-on-my-agilex%C2%AE-7-fpga-f-serie/353509
I saw there is also an I-series KDB with similar explanation on the root cause and also uses LTPowerPlay to update the over voltage protection limit to resolve SMARTVID issue but this KDB is still pending on approval.
Just take note that even though the KDB is being released, engineering is still accessing on the fix for this issue.
Kian
