FPGA-HPS DDR contention on Agilex5 SoC while running Linux: efficient data exchange strategies
Hi @ppp2 ,
Yeah, you’re right to be concerned. On Agilex 5 SoCs, if your FPGA is streaming a lot of data straight into DDR, it can hog the memory interconnect and slow down Linux or even cause memory allocations to stall. I’ve run into similar issues before.
A few things that usually help:
Throttle the FPGA traffic via HPS-FPGA bridges: Use the bridges’ QoS settings or limit burst sizes on the FPGA side so the HPS always gets guaranteed memory bandwidth. This prevents the FPGA from starving the CPU.
DMA + double buffers: Don’t let userspace hit the memory directly. Stream data via FPGA-to-HPS DMA using ping-pong or circular buffers. Userspace programs can then safely read from these buffers.
Kernel mediation: A small kernel driver exposing these buffers via mmap or a character device keeps everything safe and avoids contention on DDR.
Sync with userspace: Use interrupts, eventfd, or similar signaling mechanisms to notify userspace when new data is ready, rather than busy-waiting, which can also hammer the memory bus.
The key idea is to control FPGA memory access through the bridges and have a structured path for Linux/userspace to consume the data efficiently without blocking the HPS.
