paulgeisler's avatar
paulgeisler
1 month ago
BSP generation for I2C
How do I get the BSP generator to generate code for the I2C that I added into the platform of the max10? It generates code for the JTAG but not the I2C. I made sure that I connected the SDA and SCL l...
  • BoonBengT_Altera's avatar
    26 days ago
    Hi @paulgeisler
    The I2C driver is missing because i2c_0.csr is not connected to the Nios V data_manager. The BSP adds a driver for each peripheral that the processor masters. Exporting SDA and SCL does not make that connection.
    In Platform Designer:
    1. Connect intel_niosv_m_0.data_manager to i2c_0.csr.
    2. Set Interface for transfer command FIFO and receive data FIFO accesses to Avalon-MM Agent. In that mode the streaming ports are unused, so leave rx_data_source and transfer_command_sink unconnected.
    3. Connect i2c_0.interrupt_sender to platform_irq_rx when you want interrupt-driven transfers. The driver is still added from the csr connection. The interrupt routines are optional.
    4. Generate the HDL, then generate the BSP again. altera_avalon_i2c should appear in the BSP, with an initialization entry for i2c_0 in alt_sys_init.c.
    For the pins, sda_in and sda_oe need one bidirectional open-drain buffer, and scl_in and scl_oe need another, instantiated in the top-level design. Assigning those four ports directly to FPGA pins leaves them as separate inputs and outputs.
    Best Wishes
