Thanks @Sparrow_Altera!
Would you mind expanding on the 'additional kernel option (network namespace)'? Would it just be a case of adding
CONFIG_NET_NS=y
To the .config?
I also had a look at the snippet you shared, adapting it to my project as followed:
module dual_emac_interface (
// EMAC0 Signals
output wire emac0_mac_tx_clk_o_wire, // clock out for tx (not used in 10/100 Mbps)
input wire emac0_mac_tx_clk_i_wire, // clock in for tx (not used in 1/2.5 Gbps, but fed signal either way - should be 25MHz)
input wire emac0_mac_rx_clk_wire, // clock for rx path
output wire emac0_mac_rst_tx_n_wire, // reset for tx path
output wire emac0_mac_rst_rx_n_wire, // reset for rx path
output wire emac0_mac_txen_wire, // transmit enable signal
output wire emac0_mac_txer_wire, // transmit error signal
input wire emac0_mac_rxdv_wire, // receive data valid signal
input wire emac0_mac_rxer_wire, // receive error signal
input wire [7:0] emac0_mac_rxd_wire, // for 10/100 Mbps designs, only bits [3:0] are used
input wire emac0_mac_col_wire, // collision signal (half-duplex only)
input wire emac0_mac_crs_wire, // carrier sense signal (half-duplex only)
output wire [2:0] emac0_mac_speed_wire, // set to 3'b011 for 1 Gbps (125 MHz)
output wire [7:0] emac0_mac_txd_o_wire, // for 10/100 Mbps designs, only bits [3:0] are used
// EMAC1 Signals
output wire emac1_mac_tx_clk_o_wire,
input wire emac1_mac_tx_clk_i_wire,
input wire emac1_mac_rx_clk_wire,
output wire emac1_mac_rst_tx_n_wire,
output wire emac1_mac_rst_rx_n_wire,
output wire emac1_mac_txen_wire,
output wire emac1_mac_txer_wire,
input wire emac1_mac_rxdv_wire,
input wire emac1_mac_rxer_wire,
input wire [7:0] emac1_mac_rxd_wire,
input wire emac1_mac_col_wire,
input wire emac1_mac_crs_wire,
output wire [2:0] emac1_mac_speed_wire,
output wire [7:0] emac1_mac_txd_o_wire
reg emac0_mac_tx_clk_i_reg, emac0_mac_rxer_reg, emac0_mac_rxdv_reg;
reg [7:0] emac0_mac_rxd_reg;
reg emac1_mac_tx_clk_i_reg, emac1_mac_rxer_reg, emac1_mac_rxdv_reg;
reg [7:0] emac1_mac_rxd_reg;
assign emac1_mac_tx_clk_i_wire = emac0_mac_tx_clk_o_wire;
assign emac1_mac_rx_clk_wire = emac0_mac_tx_clk_o_wire;
assign emac1_mac_rxdv_wire = emac1_mac_rxdv_reg;
assign emac1_mac_rxer_wire = emac0_mac_txer_wire;
assign emac1_mac_rxd_wire = emac1_mac_rxd_reg;
assign emac1_mac_col_wire = 1'b0;
assign emac1_mac_crs_wire = 1'b1;
assign emac1_mac_speed_wire = 3'b011;
assign emac0_mac_tx_clk_i_wire = emac1_mac_tx_clk_o_wire;
assign emac0_mac_rx_clk_wire = emac1_mac_tx_clk_o_wire;
assign emac0_mac_rxdv_wire = emac0_mac_rxdv_reg;
assign emac0_mac_rxer_wire = emac1_mac_txer_wire;
assign emac0_mac_rxd_wire = emac0_mac_rxd_reg;
assign emac0_mac_col_wire = 1'b0;
assign emac0_mac_crs_wire = 1'b1;
assign emac0_mac_speed_wire = 3'b011;
always @ (posedge emac1_mac_tx_clk_o_wire) begin
if(!emac1_mac_rst_tx_n_wire) begin
emac0_mac_rxdv_reg <= 1'b0;
emac0_mac_rxd_reg <= 8'b0;
end else begin
emac0_mac_rxdv_reg <= emac1_mac_txen_wire;
emac0_mac_rxd_reg <= emac1_mac_txd_o_wire;
end
end
always @ (posedge emac0_mac_tx_clk_o_wire) begin
if(!emac0_mac_rst_tx_n_wire) begin
emac1_mac_rxdv_reg <= 1'b0;
emac1_mac_rxd_reg <= 8'b0;
end else begin
emac1_mac_rxdv_reg <= emac0_mac_txen_wire;
emac1_mac_rxd_reg <= emac0_mac_txd_o_wire;
end
end
endmodule
I again found the same initialisation error as here
With the emac clock tree as followed:
$ cat /sys/kernel/debug/clk/clk_summary | grep emac
root@localhost:~# cat /sys/kernel/debug/clk/clk_summary | grep emac
emaca_free_clk 1 1 0 250000000 0 0 50000 Y
emac2_clk 1 1 0 250000000 0 0 50000 Y
emac1_clk 0 0 0 250000000 0 0 50000 Y
emac0_clk 0 0 0 250000000 0 0 50000 Y
emac_ptp_free_clk 1 1 0 400000000 0 0 50000 Y
emac_ptp_clk 1 1 0 400000000 0 0 50000 Y
i2c_emac2_pclk 0 0 0 100000000 0 0 50000 Y
i2c_emac1_pclk 0 0 0 100000000 0 0 50000 Y
i2c_emac0_pclk 0 0 0 100000000 0 0 50000 Y
emacb_free_clk 0 0 0 70000000 0 0 50000 Y
Many thanks,
K
