Quartus Error When No Read Path Exists on F2H Bridge
- 8 months ago
I was able to reproduce this error internally. Indeed, the F2H bridge expected the "READ" part to be enabled. I'd say you can satisfy this by just adding a "avalon" device (like the JTAG master) to the CCT, in this way you can keep "Streaming to MM" if you wish....
Thank you very much for checking this and reproducing the issue internally.
As you explained, I understand that the F2H bridge expects the READ part to be enabled by specification.
Even if the actual data transfer in the design is write-only, the absence of a logically valid READ path would result in this error, which is the expected behavior.
Thank you for the clear explanation and confirmation.
Dear Customer,
Since a solution is provided and no further clarification is needed on this thread, it will be transitioned to community support for further help on doubts in this thread.
Please login to the Altera Community Forum and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you for the questions and as always pleasure having you here.
Best Wishes
Altera Tech Support
