NCONT ERROR in ACK for access 0 : ACK = 0x01 when trying to connect with Arm DS debugger through JTA
I am an embedded developer trying to help bring up a custom Arria 10 board. I can successfully load the SOF file to configure the FPGA using the Intel Quartus Prime Programming utility through a USB Blaster 1 connected to the JTAG interface, but when I try to manually load and run the preloader using the Arm DS debugger I get the "NCONT ERROR in ACK for access 0: ACK = 0x01" message in the Target Console window. From what I have read on the forums, this indicates that there is a JTAG COM issue with the board. I have consulted with our FPGA designer and board layout person, and they tell me the JTAG interface is configured and connected correctly. I tend to believe them since I can successfully load the SOF file through the JTAG interface. After getting the error, the debugger pops up a window stating "The target hardware identity could not be verified. Please check that the target being connected to is of type Arria 10 SoC". I have found a similar post on the Arm DS support website regarding this issue and followed the bare-metal user guide procedure for loading the preloader which worked for that person, but it did not work for me. The preloader instructions can be found at https://www.intel.com/content/www/us/en/docs/programmable/683211/current/import-preloader.html. Any help or suggestions with this issue would be greatly appreciated.
Richard
- aikeu
Hi Richard_P,
I am closing this thread for now as I was unable to reproduce the issue on my side. Do consider to contact Terasic for any hardware related issue with Han Pilot board. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Aik Eu
