keshavp
1 month agoNAND flash issue with dual-core ARM® Cortex®-A9
The 5CSEBA2U19I7SN SoC HPS NAND pins are connected to a 4Gb NAND flash memory chip (S34ML04G200TFI003). In this design, the active-low Write Protect pin (#WP) is connected to both a 10kΩ pull-up resi...
kbrunham_altera
1 month agoHi Keshav,
This structure will have WP be ~1.65V since it will be between your 2 resistors. Did you use an existing board as the reference for this NAND interface?
