Issue in booting DE10-nano with customized image
Error imgHi,
Actually, My requirement is i need to boot my DE10-nano with my customized hardware design for that i followed a document which is recommended by you
in before mail. Using quartus 21.1 tool i generated required files i.e, sof, .dtb, .rbf and so on.
I generated customized bootloader(U-boot) for DE10-nano which configure u-boot to flash fpga automatically at boottime. but i'm not able to generate
preloader so i took that from DE10_nano_xfce standard one and also i took kernal from standard one .With this i tried to boot my De10-nano i gives error.
For your reference i attached an error image.
What may be the problem, please assist me to solve this issue.
with regards,
Ragul V.
- Farabi_Altera
First need to confirm if the design example work?
link : https://www.rocketboards.org/foswiki/Documentation/DE10NanoDevelopmentBoard
regards,
Farabi
- Ragul
Booting with GHRD design example's .rbf , .dtb, u-boot.img also I'm encountering same error which is mentioned in before post.
Give me one proper document for how to boot the system with customized hardware design.
I followed the below mentioned link to boot my system . It is also useless and also i encountered lots of errors while compiling preload-er, u-boot
https://bitlog.it/20170820_building_embedded_linux_for_the_terasic_de10-nano.html
My requirement is i need to configure GPIO's(0 & 1) for HPS .By default it is in FPGA .
Sharing hardware design files for above requirement is appreciable.
With regards,
Ragul V.
- Farabi_Altera
From this design resource:
compare to your custom design, what has changed? If you change the IO, you will need to update the device tree.
regards,
Farabi
- Farabi_Altera
Its been a while since your last reply. I will put this case to community support. If you have new question, please raise new ticket, we will be happy to support.
regards,
Farabi
