Interrup numbers of Arria 10 EDAC
Hi Sue
Thank you for the quick replay.
Then I do not understand the interrupts entry in the device tree blob, where interrupt 4, 36 for emac0 rx and 5, 37 for emac0 tx is declared.
Can you explain me the four numbers? And which are the valid configuration for EMAC1?
I see for all ECC entries in the device tree a configured interrupt number: https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/tree/arch/arm/boot/dts/intel/socfpga/socfpga_arria10.dtsi?h=linux-6.6.y#n723
Where is the link of this numbers to the hardware? Or do I misunderstand something?
Are the numbers some how related with the System Manager? I mean, the documentation says that
"The ECC controller has the ability to generate single- and double-bit error interrupts to the System Manager."
see here: https://www.intel.com/content/www/us/en/docs/programmable/683711/22-3/ecc-controller-interrupts.html
Thank you,
Silvan
