Intermittent DE10-Standard error starting GDB server with quartus_hps
We've done some further testing using openFPGALoader and OpenOCD and wondering if what we have found might be related to the above preloader issue.
1. We first used quartus_cpf to create an uncompressed .rbf from intelFPGA_lite/18.1/University_Program/Computer_Systems/DE10-Standard/DE10-Standard_Computer/verilog/DE10_Standard_Computer.sof
2. We then programmed the SRAM with: openFPGALoader -c usb-blasterII --probe-firmware/opt/intelFPGA_lite/18.1/quartus/linux64/blaster_6810.hex --index-chain 1 /home/user/fpga/DE10_Standard_Computer.rbf
3. Next we used a slightly modified version of OpenOCD's altera_fpgasoc.cfg (the jtag newtap commands needed to be reversed) to run OpenOCD using test.cfg (attached): openocd -f "/home/user/fpga/openocd_test.cfg" -d2
4. We were then able to connect to the board with 'telnet localhost 4444' and run some basic test commands (halt, checked registers, etc.)
5. We added a .tcl file (prepared by my co-worker, AI-assisted, attached) to prepare CPU 0 and load /opt/intelFPGA_lite/18.1/University_Program/Monitor_Program/arm_tools/u-boot-spl.de10-standard.srec , which transfers successfully every time we've tested:
> de10_run_preloader
de10: loading preloader u-boot-spl.de10-standard.srec into on-chip RAM
34260 bytes written at address 0xffff0000
3796 bytes written at address 0xffff85d8
downloaded 38056 bytes in 1.564903s (23.748 KiB/s)
> de10_run_preloader
downloaded 38056 bytes in 1.568080s (23.700 KiB/s)
> de10_run_preloader
downloaded 38056 bytes in 1.562973s (23.778 KiB/s)
6. We then added breakpoints and an attempt to run the preloader into the .tcl file with:
bp 0xffff14f0 4 hw
resume 0xffff0000
set rc [catch { wait_halt 15000 } err]
rbp 0xffff14f0
Attempting to run the preloader succeeds about half the time with:
> de10_run_preloader
target halted in ARM state due to breakpoint, current mode: Supervisor
cpsr: 0x200001d3 pc: 0xffff14f0
MMU: disabled, D-Cache: disabled, I-Cache: enabled
de10: preloader finished (DDR3 initialized)
The other half of the time it fails (using the hardware HPS reset button between tests) with:
timed out while waiting for target halted
After adding a check for how far the preloader gets on resume shows semi-consistent failure:
Failure 1 - Error: de10: preloader did not reach 0xffff14f0 (PC=0x00002fa8)
Falure 2 - Error: de10: preloader did not reach 0xffff14f0 (PC=0x00002fa4)
Failure 3 - Error: de10: preloader did not reach 0xffff14f0 (PC=0x00002fa8)
Failure 4 - Error: de10: preloader did not reach 0xffff14f0 (PC=0x00002fa8)
Let us know if we can provide any further details. thanks again
- tehjingy_Altera11 days ago
Hi
Thank you for the additional testing, that was very useful.
Your results indicate that the stock preloader downloads into on-chip RAM reliably, but could not run till DDR initialization..
On the failing board could you try capturing the HPS UART output?
Optionally could you try repeating the test with a full board power cycle instead the reset?
