Intermittent DE10-Standard error starting GDB server with quartus_hps
Thanks for the reply. It looks like the JtagClockfrequency is set to 24 Mhz by default.
However, when running quartus_hps one of the output lines is "Successfully change hardware frequency to 16Mhz":
quartus_hps --cable="$FPGADEV" -o GDBSERVER --gdbport0=3212 --preloader=/opt/intelFPGA_lite/18.1/University_Program/Monitor_Program/arm_tools/u-boot-spl.de10-standard.srec --preloaderaddr=0xffff14f0
Info: *******************************************************************
Info: Running Quartus Prime Programmer
Info: Version 18.1.0 Build 625 09/12/2018 SJ Lite Edition
Info: Copyright (C) 2018 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details.
Info: Processing started: Mon Aug 17 11:30:35 2026
Info: Command: quartus_hps --cable="DE-SoC [1-4]" -o GDBSERVER --gdbport0=3212 --preloader=/opt/intelFPGA_lite/18.1/University_Program/Monitor_Program/arm_tools/u-boot-spl.de10-standard.srec --preloaderaddr=0xffff14f0
Current hardware is: DE-SoC [1-4]
Found HPS at device 1
Double check JTAG chain
HPS Device IDCODE: 0x4BA00477
AHB Port is located at port 0
APB Port is located at port 1
Double check device identification ...
>>CPU0 halted at 0x2fa4.
>>Resetting HPS.
>>Downloading preloader.......
>>Program loaded. PC set to program entry (0xFFFF0000)
>>Setting vector base address register to: 0xffff0000
>>Running preloader..After the above command is run 'jtagconfig --getparam "DE-SoC [1-4]" JtagClock' then shows the JtagClock is set to 16Mhz until the board is power cycled.
I tested our boards again today, and 2 showed the issue again. I tried power cycling these boards, manually setting the JtagClock with 'jtagconfig --setparam <cable_index> JtagClock <frequency>' to 16Mhz and 6Mhz before running quartus_hps, however the same issue kept persisting. No matter how many times I powered the 2 boards off and on they kept hanging at 'Downloading preloader...' and 'Running preloader...'
I then noticed after powering off the boards I could feel they were quite hot in the general area of the EPM570GF chip. Instead of power cycling the board quickly and trying the test again, I waited 1-2 minutes for the board to cool down. I then tested again and the quartus_hps command ran without issue and the GDB server started successfully.
I will test all the boards over the next few days and see if it's only these few boards which have this problem, or if it shows up intermittently across all devices. Any other suggestions are greatly appreciated. Thanks again.
Hi fpga-user
Sorry for the late reply.
Are you running a custom preloader or the GSRD preloader? If it is custom could you share what changes that you made to the preloader?
- fpga-user2 months ago
Thanks for the message. I don't believe it is a custom preloader, we are just testing with the path found in the logs in Altera Monitor Progam: /opt/intelFPGA_lite/18.1/University_Program/Monitor_Program/arm_tools/u-boot-spl.de10-standard.srec
For testing we were initially running through section 3 of the basic 'Monitor Program Tutorial for ARM' PDF (attached) adjusted for use with the DE10-Standard. When we started seeing the 'Download System - Partial Success: The system has successfully downloaded onto the board, but HPS components could not be configured' error we checked the logs and isolated the following command:
quartus_hps --cable="$FPGADEV" -o GDBSERVER --gdbport0=3212 --preloader=/opt/intelFPGA_lite/18.1/University_Program/Monitor_Program/arm_tools/u-boot-spl.de10-standard.srec --preloaderaddr=0xffff14f0We've been running that command for testing, this process hanging/timing out appears to be the same issue causing Download System error, but I could be mistaken. Let me know if I can provide any further details.
