yuvarajselvaraj's avatar
yuvarajselvaraj
10 days ago
Intel Startix 10 UART not showing up
Purchased Intel Stratix 10 board and when we tried to power on and connect the mini-usb port on HPS IO48 daughtercard to laptop/Linux machine  the port is not getting detected. tried with troubleshooting by changing the cable , restarting the board but no luck. Need input what can be done to fix it for detecting the UART port from daughter card or any other ways to access the console? like can we boot from the boards UART port?
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi
    If you could share which devkit you are using would help out with the issue.
    If you are using the Stratix10 SX devkit (https://www.altera.com/products/devkit/po-3031/stratix-10-sx-soc-development-kit) you could follow the guide here:
    https://altera-fpga.github.io/rel-26.3/embedded-designs/stratix-10/sx/soc/gsrd/ug-gsrd-s10sx-soc/
    Out of the box there are some binary image needed to be flashed on to the board.
  • sstrell's avatar
    sstrell
    Which exact dev kit?  Is this the UART for the HPS?  Link to the kit would be helpful.
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer: AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
