Intel Arria 10 SOC QSPI boot Stuck
Please find the successful log below
U-Boot 2014.10 (Jun 17 2022 - 20:49:44)
CPU : Altera SOCFPGA Arria 10 Platform
BOARD : Altera SOCFPGA Arria 10 Dev Kit
I2C: ready
DRAM: WARNING: Caches not enabled
SF: Read data capture delay calibrated to 3 (0 - 6)
SF: Detected N25Q1024A with page size 256 Bytes, erase size 4 KiB, total 128 MiB
FPGA: Early Release Succeeded.
SF: Detected N25Q1024A with page size 256 Bytes, erase size 4 KiB, total 128 MiBemif_reset interrupt acknowledged
Error: Could Not Calibrate SDRAM
DDRCAL: Failed
INFO : Skip relocation as SDRAM is non secure memory
Reserving 2048 Bytes for IRQ stack at: ffe3a6e8
DRAM : 0 Bytes
data abort
pc : [<ffe001cc>] lr : [<ffe02499>]
sp : ffe3fff0 ip : 00000016 fp : 00000001
r10: ffd02078 r9 : ffe3aee8 r8 : ffe00000
r7 : ffe1d420 r6 : 00000000 r5 : 00000000 r4 : ffeff000
r3 : ffe3afaf r2 : ffe40000 r1 : ffe3d000 r0 : ffe3aee8
Flags: nzcv IRQs on FIQs on Mode SVC_32
Resetting CPU ...
resetting ...
I2C: ready
DDRCAL: Success
DRAM : 2 GiB
SF: Read data capture delay calibrated to 8 (0 - 15)
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Model: SOCFPGA Arria10 Dev Kit
gpio_ethernet_address 1 gpio_ethernet_address+4 1Skipped ethaddr assignment due to invalid EMAC address in EEPROM
Net: dwmac.ff800000
Error: dwmac.ff800000 address not set.
Hit any key to stop autoboot: 5 4 3 2 1 0
Full Configuration Succeeded.
SF: 6225920 bytes @ 0x120000 Read: OK
SF: 32512 bytes @ 0x100000 Read: OK
FPGA BRIDGES: enable
Kernel image @ 0x008000 [ 0x000000 - 0x4dd360 ]
## Flattened Device Tree blob at 00000100
Booting using the fdt blob at 0x000100
Loading Device Tree to 01ff6000, end 01fff215 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.4.124 (nsi@nsi-HP-ProBook-440-G5) (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #3 SMP Tue Oct 12 14:38:22 IST 2021
[ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Altera SOCFPGA Arria 10
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] percpu: Embedded 18 pages/cpu s44812 r8192 d20724 u73728
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 522752
[ 0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mtdblock1 rw rootfstype=jffs2
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 2067752K/2097152K available (8192K kernel code, 557K rwdata, 1728K rodata, 1024K init, 143K bss, 29400K reserved, 0K cma-reserved, 1310720K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] ftrace: allocating 26701 entries in 53 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] L2C-310 erratum 769419 enabled
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310: enabling full line of zeros but not enabled in Cortex-A9
[ 0.000000] L2C-310 ID prefetch enabled, offset 1 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 cache controller enabled, 8 ways, 512 kB
[ 0.000000] L2C-310: CACHE_ID 0x410030c9, AUX_CTRL 0x76460001
[ 0.000000] random: get_random_bytes called from start_kernel+0x32c/0x4ec with crng_init=0
[ 0.000000] GIC: PPI13 is secure or misconfigured
[ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604467 ns
[ 0.000004] sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 21474836475ns
[ 0.000011] Switching to timer-based delay loop, resolution 10ns
[ 0.000300] Console: colour dummy device 80x30
[ 0.000325] Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=1000000)
[ 0.000334] pid_max: default: 32768 minimum: 301
[ 0.000417] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.000428] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.000904] CPU: Testing write buffer coherency: ok
[ 0.000929] CPU0: Spectre v2: using BPIALL workaround
[ 0.001127] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001562] Setting up static identity map for 0x100000 - 0x100060
[ 0.001662] rcu: Hierarchical SRCU implementation.
[ 0.001881] smp: Bringing up secondary CPUs ...
[ 0.002417] GIC: PPI13 is secure or misconfigured
[ 0.002426] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.002431] CPU1: Spectre v2: using BPIALL workaround
[ 0.002518] smp: Brought up 1 node, 2 CPUs
[ 0.002526] SMP: Total of 2 processors activated (400.00 BogoMIPS).
[ 0.002530] CPU: All CPU(s) started in SVC mode.
[ 0.003068] devtmpfs: initialized
[ 0.006173] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.006330] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.006344] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.006945] NET: Registered protocol family 16
[ 0.007913] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.008541] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.008548] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.017593] vgaarb: loaded
[ 0.017776] SCSI subsystem initialized
[ 0.017902] usbcore: registered new interface driver usbfs
[ 0.017936] usbcore: registered new interface driver hub
[ 0.017967] usbcore: registered new device driver usb
[ 0.018087] usb_phy_generic sopc@0:usbphy0: sopc@0:usbphy0 supply vcc not found, using dummy regulator
[ 0.018930] pps_core: LinuxPPS API ver. 1 registered
[ 0.018937] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.018949] PTP clock support registered
[ 0.019054] FPGA manager framework
[ 0.019652] clocksource: Switched to clocksource timer
[ 0.337257] NET: Registered protocol family 2
[ 0.337457] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.338138] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.338159] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.338214] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.338305] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.338434] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.338473] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.338620] NET: Registered protocol family 1
[ 0.338951] RPC: Registered named UNIX socket transport module.
[ 0.338959] RPC: Registered udp transport module.
[ 0.338963] RPC: Registered tcp transport module.
[ 0.338966] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.338976] PCI: CLS 0 bytes, default 64
[ 0.339414] hw perfevents: no interrupt-affinity property for /sopc@0/pmu0, guessing.
[ 0.339574] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[ 0.340376] workingset: timestamp_bits=30 max_order=19 bucket_order=0
[ 0.344827] NFS: Registering the id_resolver key type
[ 0.344850] Key type id_resolver registered
[ 0.344855] Key type id_legacy registered
[ 0.344865] Installing knfsd (copyright (C) 1996 [email protected]).
[ 0.345266] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.345459] jffs2: version 2.2. (NAND) 2001-2006 Red Hat, Inc.
[ 0.345833] bounce: pool size: 64 pages
[ 0.345844] io scheduler mq-deadline registered
[ 0.345850] io scheduler kyber registered
[ 0.349469] altvipfb2 ff200280.vip: fb0: altvipfb2 frame buffer device at 0x2e000000+0x54600
[ 0.351389] Console: switching to colour frame buffer device 60x30
[ 0.354475] dma-pl330 ffda1000.dma: Loaded driver for PL330 DMAC-341330
[ 0.354485] dma-pl330 ffda1000.dma: DBUFF-512x8bytes Num_Chans-8 Num_Peri-32 Num_Events-8
[ 0.356367] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 0.357046] printk: console [ttyS0] disabled
[ 0.357416] printk: console [ttyS0] disabled
[ 0.357447] ffc02100.serial: ttyS0 at MMIO 0xffc02100 (irq = 30, base_baud = 6250000) is a 16550A
[ 0.984366] printk: console [ttyS0] enabled
[ 0.989587] brd: module loaded
[ 0.998620] loop: module loaded
[ 1.002535] cadence-qspi ff809000.flash: n25q00a (131072 Kbytes)
[ 1.008534] 2 fixed-partitions partitions found on MTD device ff809000.flash.0
[ 1.015749] Creating 2 MTD partitions on "ff809000.flash.0":
[ 1.021399] 0x000000000000-0x000003020000 : "Boot and FPGA data"
[ 1.028231] 0x000003020000-0x000008000000 : "Root Filesystem - JFFS2"
[ 1.036271] altr_a10sr_gpio altr_a10sr_gpio.1.auto: DMA mask not set
[ 1.043098] libphy: Fixed MDIO Bus: probed
[ 1.047542] CAN device driver interface
[ 1.051597] socfpga-dwmac ff800000.ethernet: IRQ eth_wake_irq not found
[ 1.058182] socfpga-dwmac ff800000.ethernet: IRQ eth_lpi not found
[ 1.064442] socfpga-dwmac ff800000.ethernet: PTP uses main clock
[ 1.070572] socfpga-dwmac ff800000.ethernet: User ID: 0x10, Synopsys ID: 0x37
[ 1.077678] socfpga-dwmac ff800000.ethernet: DWMAC1000
[ 1.082897] socfpga-dwmac ff800000.ethernet: DMA HW capability register supported
[ 1.090351] socfpga-dwmac ff800000.ethernet: RX Checksum Offload Engine supported
[ 1.097797] socfpga-dwmac ff800000.ethernet: COE Type 2
[ 1.103002] socfpga-dwmac ff800000.ethernet: TX Checksum insertion supported
[ 1.110023] socfpga-dwmac ff800000.ethernet: Enhanced/Alternate descriptors
[ 1.116950] socfpga-dwmac ff800000.ethernet: Enabled extended descriptors
[ 1.123709] socfpga-dwmac ff800000.ethernet: Ring mode enabled
[ 1.129514] socfpga-dwmac ff800000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.137498] socfpga-dwmac ff800000.ethernet: device MAC address 4e:ee:d6:99:56:4c
[ 1.152094] libphy: stmmac: probed
[ 1.155489] Marvell 88E1510 stmmac-0:0e: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=stmmac-0:0e, irq=POLL)
[ 1.167124] dwc2 ffb00000.usb: ffb00000.usb supply vusb_d not found, using dummy regulator
[ 1.175419] dwc2 ffb00000.usb: ffb00000.usb supply vusb_a not found, using dummy regulator
[ 1.197124] dwc2 ffb00000.usb: dwc2_core_reset: HANG! AHB Idle timeout GRSTCTL GRSTCTL_AHBIDLE
[ 1.205830] dwc2: probe of ffb00000.usb failed with error -16
[ 1.211659] usbcore: registered new interface driver usb-storage
[ 1.217815] i2c /dev entries driver
[ 1.222230] Synopsys Designware Multimedia Card Interface Driver
[ 1.228422] dw_mmc ff808000.flash: IDMAC supports 32-bit address mode.
[ 1.234974] dw_mmc ff808000.flash: Using internal DMA controller.
[ 1.241065] dw_mmc ff808000.flash: Version ID is 270a
[ 1.246124] dw_mmc ff808000.flash: DW MMC controller at irq 36,32 bit host data width,1024 deep fifo
[ 1.255314] mmc_host mmc0: card is polling.
[ 1.269675] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
[ 1.372295] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 25000000Hz, actual 25000000HZ div = 1)
[ 1.382165] mmc0: new MMC card at address 0001
[ 1.387177] mmcblk0: mmc0:0001 S0J58X 59.3 GiB
[ 1.392207] mmcblk0boot0: mmc0:0001 S0J58X partition 1 31.5 MiB
[ 1.398682] mmcblk0boot1: mmc0:0001 S0J58X partition 2 31.5 MiB
[ 1.499656] altr_a10sr spi0.0: SPI transfer timed out
[ 1.504701] spi_master spi0: failed to transfer one message from queue
[ 1.719648] altr_a10sr spi0.0: SPI transfer timed out
[ 1.724683] spi_master spi0: failed to transfer one message from queue
[ 1.939647] altr_a10sr spi0.0: SPI transfer timed out
[ 1.944680] spi_master spi0: failed to transfer one message from queue
[ 2.159646] altr_a10sr spi0.0: SPI transfer timed out
[ 2.164676] spi_master spi0: failed to transfer one message from queue
[ 2.171701] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.177779] usbcore: registered new interface driver usbhid
[ 2.183338] usbhid: USB HID core driver
[ 2.187485] fpga_manager fpga0: SoCFPGA Arria10 FPGA Manager registered
[ 2.194431] oprofile: using arm/armv7-ca9
[ 2.198968] NET: Registered protocol family 10
[ 2.204035] Segment Routing with IPv6
[ 2.207726] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.214053] NET: Registered protocol family 17
[ 2.218490] NET: Registered protocol family 15
[ 2.222931] can: controller area network core (rev 20170425 abi 9)
[ 2.229128] NET: Registered protocol family 29
[ 2.233565] can: raw protocol (rev 20170425)
[ 2.237813] can: broadcast manager protocol (rev 20170425 t)
[ 2.243454] can: netlink gateway (rev 20190810) max_hops=1
[ 2.249042] 8021q: 802.1Q VLAN Support v1.8
[ 2.253259] Key type dns_resolver registered
[ 2.257544] ThumbEE CPU extension supported.
[ 2.261814] Registering SWP/SWPB emulation handler
[ 2.269034] hctosys: unable to open rtc device (rtc0)
[ 2.274088] of_cfs_init
[ 2.276601] of_cfs_init: OK
[ 2.279763] ttyS0 - failed to request DMA
[ 2.294656] random: fast init done
[ 3.009684] random: crng init done
[ 5.015667] VFS: Mounted root (jffs2 filesystem) on device 31:1.
[ 5.021791] devtmpfs: mounted
[ 5.026638] Freeing unused kernel memory: 1024K
[ 5.031318] Run /sbin/init as init process
INIT: version 2.96 booting
Starting udev
[ 5.493948] udevd[72]: starting version 3.2.9
[ 5.524300] udevd[73]: starting eudev-3.2.9
hwclock: can't o
INIT: Entering runlevel: 5
Configuring network interfaces... [ 6.201156] socfpga-dwmac ff800000.ethernet eth0: PHY [stmmac-0:0e] driver [Marvell 88E1510]
[ 6.210430] dwmac1000: Master AXI performs any burst length
[ 6.215987] socfpga-dwmac ff800000.ethernet eth0: No Safety Features support found
[ 6.223606] socfpga-dwmac ff800000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[ 6.232310] socfpga-dwmac ff800000.ethernet eth0: registered PTP clock
[ 6.238828] socfpga-dwmac ff800000.ethernet eth0: configuring for phy/rgmii-id link mode
done.
hwclock: can't open '/dev/misc/rtc': No such file or directory
Starting syslogd/klogd: done
mount: mounting /dev/mmcblk0 on /mnt failed: Invalid argument
NSI Application Star....
Config loaded from 'TC_All.ini': FPS=60, ROLL=20, Total Area=1028
pconfig->iImage_DURATION = 3
Config loaded from 'EMC_Test_Mode_1.ini': FPS=60, ROLL=10, Total Area=10
pconfig->iImage_DURATION = 1
Function_6 ---> Disable FPGA IPs
Disable Framebuffer
select the MUX output
ModeN Valid Register
Disable CVO IP
/dev/mem opened.
Memory mapped at address 0xb6fa7000.
Value at address 0xFF200010 (0xb6fa7010): 0x0
Written 0x4; readback 0x4
/dev/mem opened.
Memory mapped at address 0xb6fd0000.
Value at address 0xFF206000 (0xb6fd0000): 0x0
Written 0x1; readback 0x1
Tue Feb 27 14:01:11 UTC 2024
vinfo.xres : 480
vinfo.yres : 240
vinfo.bits_per_pixel : 24
/dev/mem opened.
Memory mapped at address 0xb6f26000.
BitFile Version : V6.2
Pixel Clock : 8.3 MHz
Firmware Version : NSI_App_V1.30
Resolution : 480x240
Bind Successful
Also We have flashed this to many boards....and all are working fine...only one board having this issue.
Please find the below env settings you asked
SOCFPGA_ARRIA10 # printenv
baudrate=115200
bootargs=console=ttyS0,115200
bootcmd=run qspirbfcore_rbf_prog; run qspiload;run set_initswstate; run qspiboot
bootdelay=5
bootimage=zImage
bootimagesize=0x5F0000
callscript=if fatload mmc 0:1 $fpgadata $scriptfile;then source $fpgadata;elseecho Optional boot script not found.Continuing to boot normally;fi;
cff_devsel_partition=0:1
core_rbf_prog=fpga loadfs 0 mmc 0:1 ${rbfcoreimage} core
ethact=dwmac.ff800000
fdt_high=0x2000000
fdtaddr=0x100
fdtimage=socfpga_arria10_socdk_qspi.dtb
fdtimagesize=0x7f00
fpga=0
fpgadata=0x2000000
fpgadatasize=0x700000
ksz9031-rgmii-clock-skew=0x3fc
ksz9031-rgmii-ctrl-skew=0x70
ksz9031-rgmii-rxd-skew=0x7777
ksz9031-rgmii-txd-skew=0x0
loadaddr=0x8000
micrel-ksz9021-clk-skew=0xf0f0
micrel-ksz9021-data-skew=0x0
mmcboot=setenv bootargs console=ttyS0,115200 root=${mmcroot} rw rootwait;fpgabr 1;bootz ${loadaddr} - ${fdtaddr}
mmcload=mmc rescan;${mmcloadcmd} mmc 0:${mmcloadpart} ${loadaddr} ${bootimage};${mmcloadcmd} mmc 0:${mmcloadpart} ${fdtaddr} ${fdtimage}
mmcloadcmd=fatload
mmcloadpart=1
mmcroot=/dev/mmcblk0p2
nandboot=setenv bootargs console=ttyS0,115200 root=${nandroot} rw rootfstype=${nandrootfstype};fpgabr 1;bootz ${loadaddr} - ${fdtaddr}
nandbootimageaddr=0x120000
nandfdtaddr=0x100000
nandload=nand read ${loadaddr} ${nandbootimageaddr} ${bootimagesize};nand read ${fdtaddr} ${nandfdtaddr} ${fdtimagesize}
nandrbfcore_rbf_prog=fpga loadfs 0 nand 0:0 ${nandrbfcoreimage} core
nandrbfcoreimage=0x820000
nandroot=/dev/mtdblock1
nandrootfstype=jffs2
netboot=dhcp ${bootimage};tftp ${fdtaddr} ${fdtimage} ; run ramboot
qspi_upage_cs=2
qspiboot=setenv bootargs console=ttyS0,115200 root=${qspiroot} rw rootfstype=${qspirootfstype};fpgabr 1;bootz ${loadaddr} - ${fdtaddr}
qspibootimageaddr=0x120000
qspifdtaddr=0x100000
qspiload=sf probe ${qspiloadcs};sf read ${loadaddr} ${qspibootimageaddr} ${bootimagesize};sf read ${fdtaddr} ${qspifdtaddr} ${fdtimagesize};
qspiloadcs=0
qspirbfaddr=0x720000
qspirbfcore_rbf_prog=fpga loadfs 0 qspi 0:0 ${qspirbfcoreimage} core
qspirbfcoreimage=0x820000
qspiroot=/dev/mtdblock1
qspirootfstype=jffs2
ramboot=setenv bootargs console=ttyS0,115200 printk.time=1 debug mem=${fdt_high} lpj=3977216;fpgabr 1; bootz ${loadaddr} - ${fdtaddr}
rbfcoreimage=ghrd_10as066n2.core.rbf
rbftosdramaddr=0x40
scriptfile=u-boot.scr
set_initswstate=mw ${u-boot_swstate_reg} ${u-boot_image_valid}
setenv_ethaddr_eeprom=ffe03659
stderr=serial
stdin=serial
stdout=serial
u-boot_image_valid=0x49535756
u-boot_swstate_reg=0xffd0620c
verify=y
Environment size: 2635/4092 bytes
