how to check the GPIO's which are available in *.dts file in linux.
I am using terasic DE10-nano.For this i downloaded the linux BSP micro SDcard image
from this site:https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=165&No=1046&PartNo=4#contents . to boot my system.
That image file has a hardware design which has GPIO's and so on. In the dts file we able to see those GPIO's .
now we want to access these GPIO in linux . we wanted to identify them in linux so that we can set the direction as input and output.
we have checked in /sys/class/gpio folder , we could not see all these GPIOs.
we want to access all the GPIO in my c Code. Please help us to identify how shall we access these GPIO and how do i see them in Linux
The below attached image provides the GPIO informations.which are in the *.dts file*.dts
Your help is highly appreciated
With regards,
Ragul V.
- Jeet14
You may need to boot your board once with the linux binaries/images.
From the log you can identify the gpiochip_id, the base address of gpio and the number bits configured in the gpio controller w.r.t your device tree *.dts file.
example from the boot log-
gpiochip_find_base: found new base at 480
gpio gpiochip0: (/soc/gpio@0xf9000270): added GPIO chardev (254:0)
gpio gpiochip0: registered GPIOs 480 to 511 on /soc/gpio@0xf9000270
*.dts file is having the node--> gpio@0xf9000270 with 32 bit.
Same you can verify from your boot log and the device tree. Later on export the gpio and set the direction. Reference-https://www.ics.com/blog/gpio-programming-using-sysfs-interface
Tiwari
- Jeet14
I believe your inquiry has been answered. With that now, I transition this thread to community support.
Thank you.
Tiwari
