How to access the 8GB ram of DDR in Agilex 7
Hi
Please find attached the uboot i am using.
Going through the device tree I see that the is a difference in the mmc node between yours and mine.
Are you using a devkit or a custom board? If it is a custom board, are you use an 8 bit sd card or a 4 bit sdcard?
Could you try changing your mmc node in the device tree to below:
&mmc {
status = "okay";
bus-width = <4>;
sd-uhs-sdr50;
cap-mmc-highspeed;
bootph-all;
Jingyang,Teh
- Gokulraj1 year ago
Hi
I'm Using Agilex 7 FPGA I-series transceiver-soc development kit(4x F-tile).
Unfortunately the shared u-boot is not working with my board.
It stops at "## Checking hash(es) for config board-0 ... OK."
I need to build u-boot for Agilex 7.so sharing u-boot source will be very useful for me.I'll compile and debug according to our need.
Gokulraj
