How to access the 8GB ram of DDR in Agilex 7
Hi
It seems like the uboot device tree was not update to map the whole 8Gb of the DRAM that you have installed.
Could you share your device tree in the forum?
I believe you could try changing the memory node to the follow:
(arch/arm/dts/socfpga_agilex7m_socdk-u-boot.dtsi)
reg = <0 0x00000000 0 0x80000000>,
<0x10 0x80000000 0x1 0x60000000>;
This should include the remaining 6 GB of your device.
Then once booted you could try accessing the address from 0x10 8000 0000 to 0x11 E000 0000
Jingyang, Teh
Even after changing the device tree as you mentioned above.Same error occurs.
Here in the u-boot dts file what ever the memory [1] region,it mapped as reserved area.
Please take a look at the bdinfo log of updated device tree log.
bdinfo log
lmb_dump_all:
memory.cnt = 0x2 / max = 0x10
memory[0] [0x0-0x7fffffff], 0x80000000 bytes flags: 0 ( 2GB )
memory[1] [0x1080000000-0x11dfffffff], 0x160000000 bytes flags: 0
reserved.cnt = 0x4 / max = 0x10
reserved[0] [0x0-0x1ffffff], 0x02000000 bytes flags: 4
reserved[1] [0x7eb08000-0x7fffffff], 0x014f8000 bytes flags: 0
reserved[2] [0x1080000000-0x11dfffffff], 0x160000000 bytes flags: 0
I believe the issue is not memory mapping node,it is reserved area mapping.
For your information,I am using Agilex 7soc not Agilex 7m and I have shared the default .dts file for your reference.
M Gokulraj
