How to access the 8GB ram of DDR in Agilex 7
Hi
It seems like the uboot device tree was not update to map the whole 8Gb of the DRAM that you have installed.
Could you share your device tree in the forum?
I believe you could try changing the memory node to the follow:
(arch/arm/dts/socfpga_agilex7m_socdk-u-boot.dtsi)
reg = <0 0x00000000 0 0x80000000>,
<0x10 0x80000000 0x1 0x60000000>;
This should include the remaining 6 GB of your device.
Then once booted you could try accessing the address from 0x10 8000 0000 to 0x11 E000 0000
Jingyang, Teh
- Gokulraj1 year ago
Even after changing the device tree as you mentioned above.Same error occurs.
Here in the u-boot dts file what ever the memory [1] region,it mapped as reserved area.
Please take a look at the bdinfo log of updated device tree log.
bdinfo log
lmb_dump_all:
memory.cnt = 0x2 / max = 0x10
memory[0] [0x0-0x7fffffff], 0x80000000 bytes flags: 0 ( 2GB )memory[1] [0x1080000000-0x11dfffffff], 0x160000000 bytes flags: 0
reserved.cnt = 0x4 / max = 0x10
reserved[0] [0x0-0x1ffffff], 0x02000000 bytes flags: 4
reserved[1] [0x7eb08000-0x7fffffff], 0x014f8000 bytes flags: 0reserved[2] [0x1080000000-0x11dfffffff], 0x160000000 bytes flags: 0
I believe the issue is not memory mapping node,it is reserved area mapping.
For your information,I am using Agilex 7soc not Agilex 7m and I have shared the default .dts file for your reference.
M Gokulraj
