High-Latency Ethernet on Arria 10 SoC device using HPS EMAC and KSZ9031
I observe a strange issue using the 1Gbps Ethernet on the Arria 10 SoC HPS. I observe the issue on our custom board and also on the Arria 10 Dev Kit. For simpler debugging, explanation and potential reproducibility, I focus now on the Dev Kit: https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/arria/10-sx.html
I built the Kernel 6.6 for the development board and use the tool `iperf3` for an Ethernet stress test. The setup is simple: Direct connection from the DevKit to a Computer. On the Dev Kit I start the "Server" with `iperf3 -s` and on the PC side, I call the client in bidirectional mode like this: `iperf3 -c <IP> --bidir`.
In parallel I start a ping on my PC console to observe the Ethernet latency. Every now and than, the ping latency increase to 500-1000ms (after the iperf3 test has finished and no data transfer is done).
It is really sporadic and doesn't happen every time. But it is some how a big issue on our product using the Arria 10 device.
I think it is some how related with an old observation: https://community.intel.com/t5/Intel-SoC-FPGA-Embedded/is-there-a-bug-in-the-Ethernet-MAC-of-Arria10-SoC-devices/m-p/1238772#M866
At this time now specific answer for the issue was found. And now the issue is back after the kernel update.
So whats happen here? And how can we get a stable Ethernet connection? Is there any patches or bugfixes available for the EMAC driver?
Cheers
Silvan
- Girisha_Dengi
Hello Silvan,
We are looking into this issue details and will get back to you on this.
Thank you.
Girisha Dengi
- Girisha_Dengi
Hello Silvan,
Altera has recently upgraded the Linux kernel version from 6.6 to 6.12.11 LTS as part of our previous quarter release.
Please upgrade the Linux kernel to this version 6.12.11 LTS and test your use case.
Link: https://github.com/altera-fpga/linux-socfpga.git
Thank you.
Girisha Dengi
- Jeet14
Hi Silvan,
Please let us know if there is any further query on this?
Tiwari
- Silvan
Hi Girisha Dengi,
Hi Tiwari
I will do the test with 6.12 on Monday. In the mean time I found a few more informations.
It seams, that the issue is not directly a delay in processing the ethernet frames. It is more like an offset in the element processing.
I check the network packages in Wireshark. In the error case, I can send a first (single) ping package and wait for an answer.
As long as nothing else is sent over the Ethernet no answer is retuned. As soon as I send a second ping package i receive the answer from the first ping package on my host PC.
When I observe the tcpdump on the Arria 10 device, I see the first ping package and its response after sending the second one.
Based on this observation I tried to get more information about the HPS MAC status. The gmacgrp_debug register https://www.intel.com/content/www/us/en/programmable/hps/arria-10/hps.html#topic/sfo1429889363845.html reports 0x120 which means, that data are present in the Rx FIFO and that the read controller is in the state of "Reading Frame Data".
It seams, that it is some how stuck in this state, and no Data are transferred to the kernel descriptors. (I checked as well the descriptors in kernel, and the are all provided and ready to use for the Ethernet DMA)
So in my opinion it seams that MACs FIFO read controller is somehow out of sync and still waiting for the end of a frame to be triggered to transfer the data... The operation mode is "Store and forward" which some how waits for the frame end.
Is there a way to get more information of the read controller? And to trigger the read out manually? I think the issue is not necessary related with kernel version. I will do the test with 6.12 next week.
regards,
silvan
- Silvan
Hi I did some tests with kernel 6.12 and see the same issue. I still think the issue is some where in the Read Controller of the Rx FIFO inside the MAC IP.
Is there any further registers for debugging available? Or any state information which can help to find and solve the issue?
Silvan
- MattG_Altera
Hi Silvan,
When you get the devkit "stuck" waiting for a receive, try issuing the command, ethtool -d <eth_interface>, to get a dump of all the registers. This might provide deeper insight into the problem.
An experiment worth trying is to change the size of the ICMP packets sent by the ping command with the -s option. I suggest trying values of 128, 129, 130, and 131 to explore alignment as being part of the problem.
Another experiment to try is to enable "busy polling" every millisecond with the following command:
# echo 1000 > /proc/sys/net/core/busy_poll
The value of the parameter is microseconds; so, I would expect the RX path would get unstuck after 1 millisecond.
Matthew
- Silvan
Hi Matthew,
Here, I can provide the additional information: First the Register values which I got with ethtool -d eth0 in the error state:
root@arria10:~# ethtool -d eth0 ST GMAC Registers GMAC Registers Reg0 0x00610C0C Reg1 0x00000404 Reg2 0x00000000 Reg3 0x00000000 Reg4 0x00003A90 Reg5 0x00003C00 Reg6 0xFFFF000E Reg7 0x00000000 Reg8 0x00001037 Reg9 0x00000120 Reg10 0x00000000 Reg11 0x00000000 Reg12 0x00020000 Reg13 0x03E80000 Reg14 0x00000001 Reg15 0x00000201 Reg16 0x80008EAC Reg17 0x9242062E Reg18 0x00000000 Reg19 0x00000000 Reg20 0x00000000 Reg21 0x00000000 Reg22 0x00000000 Reg23 0x00000000 Reg24 0x00000000 Reg25 0x00000000 Reg26 0x00000000 Reg27 0x00000000 Reg28 0x00000000 Reg29 0x00000000 Reg30 0x00000000 Reg31 0x00000000 Reg32 0x00000000 Reg33 0x00000000 Reg34 0x00000000 Reg35 0x00000000 Reg36 0x00000000 Reg37 0x00000000 Reg38 0x00000000 Reg39 0x00000000 Reg40 0x00000000 Reg41 0x00000000 Reg42 0x00000000 Reg43 0x00000000 Reg44 0x00000000 Reg45 0x00000000 Reg46 0x00000000 Reg47 0x00000000 Reg48 0x00000000 Reg49 0x00000000 Reg50 0x00000000 Reg51 0x00000000 Reg52 0x00000000 Reg53 0x00000000 Reg54 0x0000000D DMA Registers Reg0 0x01900880 Reg1 0x00000000 Reg2 0x00000000 Reg3 0x027B0000 Reg4 0x027B8000 Reg5 0x00660404 Reg6 0x02202906 Reg7 0x0001A061 Reg8 0x000000B7 Reg9 0x00000000 Reg10 0x00FF0009 Reg11 0x00000000 Reg12 0x00000000 Reg13 0x00000000 Reg14 0x00000000 Reg15 0x00000000 Reg16 0x00000000 Reg17 0x00000000 Reg18 0x027B9FE0 Reg19 0x027B3DC0 Reg20 0x030047CA Reg21 0x02E0F000 Reg22 0x170D69BF root@arria10:~#I did the tests with the ping message size (-s option). It has no impact or changes in the behavior. On my host PC I started a tcpdump which results in the following output:
11:59:55.158944 IP heldsksm1 > 192.168.2.72: ICMP echo request, id 21008, seq 1, length 136 11:59:55.159162 IP 192.168.2.72 > heldsksm1: ICMP echo reply, id 20934, seq 1, length 64 12:00:02.411714 IP heldsksm1 > 192.168.2.72: ICMP echo request, id 21139, seq 1, length 137 12:00:02.412154 IP 192.168.2.72 > heldsksm1: ICMP echo reply, id 21008, seq 1, length 136 12:00:09.874869 IP heldsksm1 > 192.168.2.72: ICMP echo request, id 21356, seq 1, length 138 12:00:09.875066 IP 192.168.2.72 > heldsksm1: ICMP echo reply, id 21139, seq 1, length 137 12:00:27.903913 IP heldsksm1 > 192.168.2.72: ICMP echo request, id 21687, seq 1, length 139 12:00:27.904126 IP 192.168.2.72 > heldsksm1: ICMP echo reply, id 21356, seq 1, length 138 12:00:32.869880 IP heldsksm1 > 192.168.2.72: ICMP echo request, id 21766, seq 1, length 64 12:00:32.870074 IP 192.168.2.72 > heldsksm1: ICMP echo reply, id 21687, seq 1, length 139The reply is always that one from the previous request, not from the current one. It is independent of the time, when the new request was sent.
In parallel I executed tcpdump also on the Arria 10 device:
08:03:56.351322 IP 192.168.2.201 > arria10: ICMP echo request, id 20934, seq 1, length 64 08:03:56.351389 IP arria10 > 192.168.2.201: ICMP echo reply, id 20934, seq 1, length 64 08:04:03.604107 IP 192.168.2.201 > arria10: ICMP echo request, id 21008, seq 1, length 136 08:04:03.604171 IP arria10 > 192.168.2.201: ICMP echo reply, id 21008, seq 1, length 136 08:04:11.067233 IP 192.168.2.201 > arria10: ICMP echo request, id 21139, seq 1, length 137 08:04:11.067297 IP arria10 > 192.168.2.201: ICMP echo reply, id 21139, seq 1, length 137 08:04:29.096255 IP 192.168.2.201 > arria10: ICMP echo request, id 21356, seq 1, length 138 08:04:29.096331 IP arria10 > 192.168.2.201: ICMP echo reply, id 21356, seq 1, length 138 08:04:34.062204 IP 192.168.2.201 > arria10: ICMP echo request, id 21687, seq 1, length 139 08:04:34.062267 IP arria10 > 192.168.2.201: ICMP echo reply, id 21687, seq 1, length 139It seams, that the Arria10 device get the ping messages and immediately reply to them. But we can see the package offset. The Arria 10 device gets the "old" 64bytes long messages and reply to them where the host was sending the 136bytes message.
Based on that observation and in combination with the information of the Register 9 (gmacgrp_debug), it seams, that the offset source is in the Rx path. It seams, that the Rx FIFO readout controller is responsible for this offset. Do you know any Registers to get more information about the Readout controller of the MAC?
I think, in the current case, there is no option on OS level to influence this directly, because the offset is down in the MAC hardware.
I tried also the "polling" configuration which you suggested and additional I set them also for /proc/sys/net/core/busy_read. Both of them doesn't changed anything.
When we think, that it is probably an issue in the FIFO readout controller, I would also expect no behavior change based on the polling setting. This because, the polling setting works on the "Descriptors" in the kernel memory and not the FIFO state.
Any idea how we can solve the issue? Or how we can get more information about the root cause? Maybe it is possible to trigger the FIFO read controller manually? To get them back in sync?
Thanks you for your support and best regards,
Silvan
- rgthomas
Hi Silvan,
I think I was able to reproduce the issue on our setup consistently, just by running the iperf3 server with UDP 64-byte packets sent from the host machine at line rate.
root@arria10:~# iperf3 -s ----------------------------------------------------------- Server listening on 5201 (test #1) ----------------------------------------------------------- Accepted connection from 192.168.2.100, port 37872 [ 5] local 192.168.2.40 port 5201 connected to 192.168.2.100 port 57154 [ ID] Interval Transfer Bitrate Jitter Lost/Total Datagrams [ 5] 0.00-1.00 sec 6.25 MBytes 52.4 Mbits/sec 0.006 ms 154296/256751 (60%) [ 5] 1.00-2.00 sec 6.27 MBytes 52.6 Mbits/sec 0.006 ms 156917/259573 (60%) [ 5] 2.00-3.00 sec 6.26 MBytes 52.5 Mbits/sec 0.007 ms 157229/259797 (61%) [ 5] 3.00-4.00 sec 6.26 MBytes 52.5 Mbits/sec 0.006 ms 157367/259983 (61%) [ 5] 4.00-5.00 sec 6.26 MBytes 52.5 Mbits/sec 0.006 ms 157039/259623 (60%) [ 5] 5.00-6.00 sec 6.25 MBytes 52.4 Mbits/sec 0.009 ms 158735/261174 (61%) [ 5] 6.00-7.00 sec 6.25 MBytes 52.5 Mbits/sec 0.012 ms 157964/260420 (61%) [ 5] 7.00-8.00 sec 6.26 MBytes 52.5 Mbits/sec 0.006 ms 162000/264503 (61%) [ 5] 8.00-9.00 sec 6.26 MBytes 52.5 Mbits/sec 0.011 ms 162404/265020 (61%) [ 5] 9.00-10.00 sec 6.27 MBytes 52.6 Mbits/sec 0.006 ms 162334/265030 (61%) [ 5] 10.00-10.42 sec 22.8 KBytes 445 Kbits/sec 12.748 ms 611/976 (63%) - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Jitter Lost/Total Datagrams [ 5] 0.00-10.42 sec 62.6 MBytes 50.4 Mbits/sec 12.748 ms 1586896/2612850 (61%) receiver ----------------------------------------------------------- Server listening on 5201 (test #2) ----------------------------------------------------------- ^Ciperf3: interrupt - the server has terminated root@arria10:~# ping 192.168.2.100 -c 10 PING 192.168.2.100 (192.168.2.100): 56 data bytes 64 bytes from 192.168.2.100: seq=0 ttl=64 time=1000.462 ms 64 bytes from 192.168.2.100: seq=1 ttl=64 time=1000.344 ms 64 bytes from 192.168.2.100: seq=2 ttl=64 time=1000.377 ms 64 bytes from 192.168.2.100: seq=3 ttl=64 time=1000.363 ms 64 bytes from 192.168.2.100: seq=4 ttl=64 time=1000.367 ms 64 bytes from 192.168.2.100: seq=5 ttl=64 time=1000.374 ms 64 bytes from 192.168.2.100: seq=6 ttl=64 time=1000.347 ms 64 bytes from 192.168.2.100: seq=7 ttl=64 time=1000.349 ms 64 bytes from 192.168.2.100: seq=8 ttl=64 time=1000.363 ms --- 192.168.2.100 ping statistics --- 10 packets transmitted, 9 packets received, 10% packet loss round-trip min/avg/max = 1000.344/1000.371/1000.462 msAs you have pointed out earlier in this thread, the gmacgrp_debug register has a value of 0x00000120 at my setup also. With this, I think there is an issue with the EMAC IP on Arria 10, and the issue seems reproducible when we hit the Rx buffer unavailable condition repeatedly. We need to follow up with Synopsis on this issue.
I tried a different configuration for the MTL RX FIFO and Rx DMA, and I can see the issue is not reproducible in this case. What I've done is set the dff bit of the dmagrp_operation_mode register. By setting this bit, we can disable flushing of the received frames when the Rx buffer unavailable condition is met. But in this setting, we need to write to the dmagrp_receive_poll_demand register after refilling the descriptor ring. Attached a patch for these changes. With these changes, I can see flow control working effectively and with almost 0% packet loss for the same iperf3 test. Also, the issue is not reproducible.
root@arria10:~# iperf3 -s ----------------------------------------------------------- Server listening on 5201 (test #1) ----------------------------------------------------------- Accepted connection from 192.168.2.100, port 43988 [ 5] local 192.168.2.25 port 5201 connected to 192.168.2.100 port 57459 [ ID] Interval Transfer Bitrate Jitter Lost/Total Datagrams [ 5] 0.00-1.00 sec 6.52 MBytes 54.6 Mbits/sec 0.007 ms 858/107663 (0.8%) [ 5] 1.00-2.00 sec 6.58 MBytes 55.2 Mbits/sec 0.007 ms 0/107776 (0%) [ 5] 2.00-3.00 sec 6.50 MBytes 54.5 Mbits/sec 0.012 ms 694/107232 (0.65%) [ 5] 3.00-4.00 sec 6.57 MBytes 55.1 Mbits/sec 0.007 ms 0/107688 (0%) [ 5] 4.00-5.00 sec 6.55 MBytes 55.0 Mbits/sec 0.007 ms 0/107392 (0%) [ 5] 5.00-6.00 sec 6.55 MBytes 55.0 Mbits/sec 0.018 ms 0/107343 (0%) [ 5] 6.00-7.00 sec 6.56 MBytes 55.0 Mbits/sec 0.006 ms 0/107448 (0%) [ 5] 7.00-8.00 sec 6.56 MBytes 55.1 Mbits/sec 0.005 ms 0/107536 (0%) [ 5] 8.00-9.00 sec 6.55 MBytes 55.0 Mbits/sec 0.008 ms 0/107344 (0%) [ 5] 9.00-10.00 sec 6.56 MBytes 55.0 Mbits/sec 0.027 ms 0/107488 (0%) [ 5] 10.00-10.01 sec 86.6 KBytes 54.1 Mbits/sec 0.008 ms 0/1386 (0%) - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Jitter Lost/Total Datagrams [ 5] 0.00-10.01 sec 65.6 MBytes 54.9 Mbits/sec 0.008 ms 1552/1076296 (0.14%) receiver ----------------------------------------------------------- Server listening on 5201 (test #2) ----------------------------------------------------------- ^Ciperf3: interrupt - the server has terminated root@arria10:~# ping 192.168.10.2.100 -c 10 PING 192.168.2.100 (192.168.2.100): 56 data bytes 64 bytes from 192.168.2.100: seq=0 ttl=64 time=0.336 ms 64 bytes from 192.168.2.100: seq=1 ttl=64 time=0.315 ms 64 bytes from 192.168.2.100: seq=2 ttl=64 time=0.294 ms 64 bytes from 192.168.2.100: seq=3 ttl=64 time=0.286 ms 64 bytes from 192.168.2.100: seq=4 ttl=64 time=0.243 ms 64 bytes from 192.168.2.100: seq=5 ttl=64 time=0.237 ms 64 bytes from 192.168.2.100: seq=6 ttl=64 time=0.317 ms 64 bytes from 192.168.2.100: seq=7 ttl=64 time=0.276 ms 64 bytes from 192.168.2.100: seq=8 ttl=64 time=0.249 ms 64 bytes from 192.168.2.100: seq=9 ttl=64 time=0.254 ms --- 192.168.2.100 ping statistics --- 10 packets transmitted, 10 packets received, 0% packet loss round-trip min/avg/max = 0.237/0.280/0.336 msAttached patch for these changes. This patch is for checking the behavior on your side and is on socfpga-6.12.11-lts branch. This patch is not fully tested. Once booted with the image having the above patch you can use devmem2 tool to make sure dff bit is set for the dmagrp_operation_mode register and after that you can repeat the above test and can confirm issue is reproducible or not. Atleast on my side I can see the issue is not reproducible.
root@arria10:~# devmem2 0xFF801018 /dev/mem opened. Memory mapped at address 0xb6fad000. Read at address 0xFF801018 (0xb6fad018): 0x03202906Please try and confirm the behavior on your setup.
Rohan
- Silvan
Hi Rohan,
Thank you so much for the description and the provided patch. I applied the patch for the dev board and it works as expected.
Additionally, I created the same patch for kernel 6.6 and a first short test on our hardware was also successful. I will run more detailed tests on our hardware this week. But I am optimistic that it will work.
For us it would be beneficial if the patch becomes available in the mainline version of the Linux kernel. Do you think, this could be possible? If required, I will support you for that.
For the discussion with Synopsis I have a few additional info:
We have also a old Cyclone V Dev Board. As I saw in the device documentation, there is a similar MAC. Version 3.70a in Cyclone V and 3.72a in Arria 10.
I did the same test on the Cyclone V and observed the same issue as well.
- rgthomas
Hi Silvan,
Thanks for sharing the update — glad to hear the patch resolves the issue. It seems the EMACs in Cyclone V, Arria 10, and Agilex7 exhibit this behavior. We'll follow up with Synopsys for further clarification.
We're planning to integrate the workaround in our next quarterly release. If you're considering upstreaming it to the mainline Linux kernel, you're welcome to do so. Just make sure to update the commit subject and description according to the upstream guidelines (currently, commit message is written as a workaround), and also please ensure the patch adheres to kernel coding standards.
Also, please let us know if you observe any regressions during your testing.
Rohan - tehjingy_Altera
Hi
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang, Teh
