ERROR: Config PwrMgr handoff failed. error -1
Hello
The error that you are seeing is observed in the First Stage Boot Loader(FSBL), which corresponds to ATF in this flow. This is related to the SDRAM bring-up. From the hardware configuration, some settings (stored in the bitrstream in QSPI) are read by the FSBL and this configures some HPS/EMIF registers to bring some peripherals or the SDRAM. In this case, seems that the problem is related to any incorrect configuration in the hardware design in the pss_sram_power_off() function (https://github.com/altera-fpga/arm-trusted-firmware/blob/socfpga_v2.13.0/plat/intel/soc/agilex5/soc/agilex5_power_manager.c#L42), which is reporting a failure.
Unfortunately, we have not updated the Zephyr GSRD after 24.3, so the instructions in https://altera-fpga.github.io/rel-24.3/embedded-designs/agilex-5/e-series/premium/gsrd_zephyr/ug-zgsrd-agx5e-premium/ have not been tested with Quartus 25.3.
Now, the failure that you see is observed at ATF stage before Zephyr is launched, and we support some flows that also use ATF as bootloader. The flow described in Direct ATF to Linux Boot (https://altera-fpga.github.io/rel-25.3/embedded-designs/agilex-5/e-series/premium/boot-examples/ug-linux-boot-agx5e-premium/#boot-from-qspi_1) can be used as a reference to build your hardware desgin and your ATF for 25.3 release. You can build these and then use it with your original Zephyr build instructions and see if your error is not longer seen. You can also compare the HPS configuration in Quartus between your current hardware build and the one that you create using the Direct ATF to Linux Boot and identify any difference that could be creating the error that you are seeing.
Please let me know if this information helps you to move forward.
Rolando
- RolandoS_Altera1 year ago
Hello, I just tried to build a simple Zephyr Hello World application using the Toolchain setup, GHRD, ATF instructions from https://altera-fpga.github.io/rel-25.3/embedded-designs/agilex-5/e-series/premium/boot-examples/ug-linux-boot-agx5e-premium/#boot-from-qspi_1 together with the Zephyr instructions in the https://altera-fpga.github.io/rel-24.3/embedded-designs/agilex-5/e-series/premium/gsrd_zephyr/ug-zgsrd-agx5e-premium/ and this is working correctly as you can see below:
NOTICE: DDR: Reset type is 'Power-On'
NOTICE: IOSSM: Calibration success status check...
NOTICE: IOSSM: All EMIF instances within the IO96 have calibrated successfully!
NOTICE: DDR: Calibration success
NOTICE: DDR: ECC is enabled
NOTICE: IOSSM: Memory initialized successfully on IO96B
NOTICE: ###DDR:init success###
NOTICE: DFI interface selected successfully to SDEMMC
NOTICE: SOCFPGA: QSPI boot
NOTICE: BL2: v2.13.0(release):QPDS25.3_REL_GSRD_PR
NOTICE: BL2: Built : 15:51:35, Oct 22 2025
NOTICE: BL2: Booting BL31
NOTICE: SOCFPGA: Boot Core = 0
NOTICE: SOCFPGA: CPU ID = 0
NOTICE: SOCFPGA: Setting CLUSTERECTRL_EL1
NOTICE: BL31: v2.13.0(release):QPDS25.3_REL_GSRD_PR
NOTICE: BL31: Built : 15:51:35, Oct 22 2025
*** Booting Zephyr OS build b755e7bab5f8 ***
Secondary CPU core 1 (MPID:0x100) is up
Secondary CPU core 2 (MPID:0x200) is up
Secondary CPU core 3 (MPID:0x300) is up
Hello World! intel_socfpga_agilex5_socdkThanks
Rolando
