DS-5 Install Not Detected - SoC EDS May Not Function Correctly
Hi
Please find my answers below:
1.What might be causing this issue?
This warning does not cause any functionality issue when debugging.
You may still continue to use it to debug.
2.How can I resolve it to ensure that the SoC EDS functions correctly?
Could you check if you are following the steps for SoC EDS according to the link below:
https://www.rocketboards.org/foswiki/Documentation/SoCEDS#Starting_Embedded_Command_Sh_AN1
3.Is there a specific DS-5 installation required for this version of the Intel FPGA Pro Edition?
Please note that the SoCED have been discontinued.
The DS-5 was last tested with using Intel FPGA Pro 20.1 and SoCED 20.1.
4.Are there any alternative solutions or workarounds if DS-5 is no longer supported or available?
Alternative for the DS-5 is the RiscFree IDE.
https://www.intel.com/content/www/us/en/docs/programmable/730783/23-4/about-the-ide.html
Jingyang, Teh
- Balkesh2 years ago
Hi @JingyangTeh_Altera ,
I have been following the quide for installing SoC EDS and Arm DS-5. But while executing the command embedded_command_shell.sh i'm getting the following error WARNING: DS-5 install not detected. SoC EDS may not function correctly without a DS-5 install.
I am using Intel FPGA Pro 20.1 and SoCED 20.1.
Can I use directly DS-5 without Intel SOCEDs? If yes what will be the advantages of using SOCEDs. Do I face any problem.
Actually I want to use HPS to manage descriptors of MSGDMA IP so what I have to configure in HPS for this and do i need DS-5 and SOCEDs for this. Actually I am first time using HPS.
