De10 standard connects to esp8266 via uart communication by IP uart (rs-232 serial port)
- 3 years ago
Hi Allen
Do you have a scope available to measure the signals coming out from the pins?
Do you have the specification for the USB transceiver that you are using? What operating signal logic it is able to capture?
The signals coming out from the GPIO are 3.3Vs.
Jingyang, Teh
Hi Jingyang, Teh
I send you some waveforms corresponding to some cases.
1. configure set fixed baudrate 9600 in qsys:
waveform correct with data "57" but baudrate is not correct (a)waveform correct with data "57" but baudrate is not correct (b)
2. uncheck set fixed baudrate in qsys:
when i set clock = 50M and divisor = 7400 then it correct all.
waveform when i set divisor = 7400
I hope with the information I provided you can find the source of the error.
Alen (Phan Quang Ky)
