Alen1214
3 years agoDe10 standard connects to esp8266 via uart communication by IP uart (rs-232 serial port)
Hi, I need to communicate between de10 and esp8266 to send data to the cloud, but first I need to connect these 2 kits base on project GHRD. I see they can connect with each other by IP uart rs232 an...
- 3 years ago
Hi Allen
Do you have a scope available to measure the signals coming out from the pins?
Do you have the specification for the USB transceiver that you are using? What operating signal logic it is able to capture?
The signals coming out from the GPIO are 3.3Vs.
Jingyang, Teh
tehjingy_Altera
3 years agoHi Alen
Glad that you are able to get your project working.
Could you please share the wave form that you have and a screenshot of the settings that you done in the IP?
What version of the quartus that you are using currently?
I will raise this up to the engineering team to investigate this issue further as this is not an expected behaviour.
Jingyang, Teh
