Alen1214
3 years agoDe10 standard connects to esp8266 via uart communication by IP uart (rs-232 serial port)
Hi, I need to communicate between de10 and esp8266 to send data to the cloud, but first I need to connect these 2 kits base on project GHRD. I see they can connect with each other by IP uart rs232 an...
- 3 years ago
Hi Allen
Do you have a scope available to measure the signals coming out from the pins?
Do you have the specification for the USB transceiver that you are using? What operating signal logic it is able to capture?
The signals coming out from the GPIO are 3.3Vs.
Jingyang, Teh
tehjingy_Altera
3 years agoHi Allen
Jingyang, Teh
Alen1214
3 years agohi JingyangTeh,
Thank you so much for your support. I succeeded in this application. The problem : the baudrate of IP in the manual is not true to reality.
regards,
alen
