Alen1214
3 years agoDe10 standard connects to esp8266 via uart communication by IP uart (rs-232 serial port)
Hi, I need to communicate between de10 and esp8266 to send data to the cloud, but first I need to connect these 2 kits base on project GHRD. I see they can connect with each other by IP uart rs232 an...
- 3 years ago
Hi Allen
Do you have a scope available to measure the signals coming out from the pins?
Do you have the specification for the USB transceiver that you are using? What operating signal logic it is able to capture?
The signals coming out from the GPIO are 3.3Vs.
Jingyang, Teh
tehjingy_Altera
3 years agoHi Alen
Have you tried using a different tool that supports setting stop bit?
There are a few that I have used before: Teraterm & putty.
Jingyang, Teh
Alen1214
3 years agohi,I have tried using putty but it's not correct.
puttyputtyterminal
Tomorrow, I will try with configure some parameters : not "fixed baud rate" or "baud =9600". sometime, I think With clock 50M and baud 115200 maybe make larger speed error.
regards,
Alen
