Alen1214
3 years agoDe10 standard connects to esp8266 via uart communication by IP uart (rs-232 serial port)
Hi, I need to communicate between de10 and esp8266 to send data to the cloud, but first I need to connect these 2 kits base on project GHRD. I see they can connect with each other by IP uart rs232 an...
- 3 years ago
Hi Allen
Do you have a scope available to measure the signals coming out from the pins?
Do you have the specification for the USB transceiver that you are using? What operating signal logic it is able to capture?
The signals coming out from the GPIO are 3.3Vs.
Jingyang, Teh
tehjingy_Altera
3 years agoHi Alen1214
From the address map I see that UART IP is connected to the light-weight F2H and an offset of 0x7000.
The LWF2H start address is 0xFF200000.
Could you try accessing the address 0xFF207000 as your h2p_lw_uart_addr?
Jingyang, Teh
Alen1214
3 years agoHi Jingyang, Teh,
You can get project GHRD at link I was upload:
https://drive.google.com/file/d/1Bse1dQUNYEjjC0GkylL1VpXxlSVzFtoI/view?usp=sharing
Alen1214
